Question about Brother MFC 7420 All-In-One Laser Printer
A 1/4" vertical gray line off center prints on copies and faxes
It's a light gray line that has letters in it like this:
AT
IO
EN
that repeat several times aboiut 2.5" apart. Above and below the letters are curved lines, almost like a postmark. I cleaned the glass, and changed both the toner cartridge and the drum. Where is this coming from??!
  • sjs8 Apr 14, 2009
    The guy who helped me yesterday said that it was the fuser. A fuser costs $132.50 for a replacement. I ordered a replacement machine (refurbished, but with a full warranty) for $79.98. Thank you, though.
  • 215 Answers
Chances are that its coming from your heat roller. if you open rear cover and look closely, you will see a unit with an orange colored lower roller, and the upper one is your heat roller. if you inspect upper roller, you should see the defect. its a teflon coated roller and sounds like teflon has worn off. you will have to have that replaced.
hth,
razors
Posted on Apr 14, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Print quality
Sounds like the scanner led head. Try to look in under the scanner when doing a copy to see if it is fully lit, can be a pig to rplace, some brother parts are not too expensive but you will need an engineer to order it and fit it
May 12, 2009 | Brother Office Equipment & Supplies
Canon l80 faxphone "repeating image" on sheet several times?
It sounds like it is most likely a bad cartridge. Try replacing it.
Nov 10, 2008 | Canon FAXPHONE L80 Laser
Line almost straight down center when receiving fax
if you try a internal print such as a report does it go away? if so its more lucky the person sending you the fax.
if you print a report and its on there i would check the ribbon and look for marks, also it could be a transfer problem causing these marks.
Hope this gives you a starts
Oct 21, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
Clear vertical lines when printing that do not clear up by shaking toner
does it do it on copies and internal test as well???
1- check the thin strip of glass inside the machine and make sure it is clean, look at the toner are there any line on there that corresponds?? yes then replace.it could be coming from the drum or toner. I beleive the drum is a seperate piece from the toner
Aug 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines on received faxes
look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Black line on my fax copies!
    You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
    Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
    Brother MFC 7420 All-In-One Laser Printer Logo
    112 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
