Question about HP LaserJet 8150 Printer
Printer does not recognize color cartridge for my HP OfficeJet 7410
After inserting a brand new color cartridge I get an error message to remove cartridge and reinsert. I've made sure the tape is off. Sometimes a second message tells me the cartridge is not compatible with this printer. It is the exact same cartridge from Staples. Is there something I can try without first going to a repairman. jdixieland@aol.com Two separate ink cartridges, purchased from full-line stores, identified by box and contents as genuine HP ink cartridges.... not recognized by the printer.
What should I do??
dene@usa.com
  • 29 Answers
Its a broken spring clip on the side of the ink cartridge.
fixes are here;
http://www.fixyourownprinter.com/forums/inkjet/46650#83
and here;
http://www.fixyourownprinter.com/forums/inkjet/50913#243
hp is supposed to give you a brand new printer for free.
Posted on Aug 31, 2009
Error message says check color print cartridge. We've removed and reinstalled several times and the message is still there.
Remove the color cartridges and insure that the spring in not loose. Also look at the printer circuit in the back for pin holes.
Feb 01, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Receiving a "Insert color cartridge" error message
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
Jun 19, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer does not recognize new color cartridge
Make sure you have taken the orange tape off the print cartridge.The printer will not recognize the cartridge with the tape on
Mar 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
Oct 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Repeated error message
Very Simple, Probably...
Just remove the cartridge and see if the metal spring clip has broken away from the right wall. If it has, inspect the gold colored circuit board at the back of the cartridge bay...there is probably a hole or dent where the clip slammed into it.
If you have these symptoms, go to HP, and go to the chat support window, describe your problem, and they will send you a replacement printer.
It's exactly what I did.
Jan 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP LaserJet 8150 Printer Logo
549 people viewed this question
Seeker5211
Seeker5211
