Question about Air Purifiers
Vaillant boiler - heating OK, but no hot water.
Hi, I have a Vaillant TURBOmax VUW 242/1E combi boiler. Recently the instant hot water has stopped working. Central heating is fine, but when I run the hot tap (upstairs and down) the boiler just doesn't react. It doesn't try and ignite or anything. Any clues??
  • Anonymous Apr 24, 2009
    Hi there.. Any luck on the problem? I have the same problem now.. Thanks in advance.
  • christhebant Apr 26, 2009
    Thanks for the advice!! I actually had a mate of mine come around and have a look - he diagnosed it as a the flow switch not making a connection.
    To remedy this he packed the underside of the flow switch with a small piece of card - thus raising the contact of the switch slightly - and this worked a treat!! So i now have hot water again and spent absolutely no money at all.
    Hope you find this helpful!!!
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
Have a vailiant combi have no hot water.had new heat exchanger put on and diverter valve is 2 years old.heating is fine what could be problem
Posted on Jan 02, 2010
Sunbeam instruction manuals
Hi! If your cleaner is not steaming it could be that the steamer pump is not on, or there is no water or not enough water in the tank. I have included a link to the instruction manual. If it is still not steaming please contact customer support at 1-800-321-1134. Thanks! http://dirtdevil.com/file/235/
Aug 30, 2014 | Dirt Devil Pd20000 Easy Steam Mop
Bleeding the radiator
take the top off the header tank ( part you fill the water in) top to the top run engine until it boils or fan kicks in to cool down the engine. while it is heating up squeeze the pipes around the engine to help release the air better DONT put your hands near any moving parts. keep the water full to the top while doing this. when at temp turn off engine and leave to cool down dont add any water or do anything till it has cooled down. when cooled down top up to the mark and should be good then if not then the thermostat may be faulty. or you have a blockage some were in the system that is causing the over boiling problem also check that the fan is working and the temp switch for the fan is working all these can make the engine over heat, also when bleeding the system have the heater on number one and heat on full.
Apr 02, 2014 | Spectre 2001 Chrysler Concorde - 2.7L V6 -...
Vaillant turbomax vuw gb 282e hot water problem
Check for a control on the gas valve. Has this unit ever been hot? How long installed? Is it jetted for the right gas?
Dec 01, 2013 | Air Purifiers
Where is the thermostat?
a thermostat is always located on top hose from radiator.. just follow ur hose from radiator to engine block when the hose stops then u found it i have not seen a thermostat been any where else, as i been working on cars 9 years ...
Sep 29, 2012 | EBC Brakes 2000 Chrysler Concorde - 3.2L...
We have model 11502 air purifier. Recently turned it on and it ran for a few minutes and then stopped. Motor sounded fine- no squealing, didn't slow down before it went off- just stopped like it was...
Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
Jan 05, 2011 | Honeywell Air Purifiers
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a fresh air by Ecoquest the motor stops
I recently fixed one with the same problem. Remove the rear cover where the switch is mounted. (Take off the filter first) The wires have enough length that it is not necessary to remove them. Use a blow dryer and blow into the opening to remove dust and moisture from the circuit boards. Either one will make it start and stop. Make sure not to get it too hot or too close. Good Luck. I can't help you with the dealer question as I'm in NC.
Mar 22, 2009 | Ecoquest Fresh Air Living Air Purifier
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Kenmore AC2044-1 question ASAP!
If it says "Clean Cell Now" and it is a new machine, it is broken. I have six, yes six, of this model. They are all new and you shouldn't have to clean the filter/cells for a few months.
The way to clean is:
  1. Unplug
  2. remove the white cover
  3. remove the prefilter. Good time to clean the prefilter by removing the 2 retention clips and gently swing the prefilter outward. Clean or groom it with a vacuum. Use the upholstery brush. wash the prefilter in warm, soapy water. No Chlorine! Rinse clean with regular water. Wipe with a paper towel and let dry completely. It is okay to gently use a hair blower to speed up the drying process.
  4. Onto the Cell.
  5. The cell can be washed one of two ways. Either in a hot tub of water or in a dishwasher.
  6. Wear gloves to protect your hands. Never touch the fins or wires. It will ruin them and cut you up. Use the two handles.
  7. Use hot water and dish detergent.
  8. No chlorine and no abrasives.
  9. Soak for 10 minutes, then dip a couple of times to remove stuck dust/dirt/schmutz.
  10. Rinse with clean water.
  11. Allow to dry
  12. Allow to dry
  13. Allow to dry
  14. Okay to use a hair dryer to speed up process.
  15. Reinstall
  16. Power up
  17. Press and hold CHECK button for 3 secs to reset.
Thanks.
Jan 10, 2008 | Kenmore AC2044-1 Air Purifier
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Oct 16, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Air Purifiers Logo
8,711 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
