Question about Vizio L32 32 in. LCD HDTV
How to clean screen
We have lost track of our VISIO VW 42L HDTV manual and do not remember what you use to clean the screen. We do not want to spray glass cleaner on it unless its okay. Please reply to email address below. thanks So much.
I have two Vizio televisions. I have both a plasma and an LCD TV. The manuals for both televisions recommend nothing other than a soft cloth. I use a microfiber cloth that is meant for cleaning glasses. If there is something smudged on the television then I put a small amount of water on the cloth so that it is barely damp and follow right after with a dry cloth. I have heard many things about using baby wipes, alcohol and even laundry softner. I would never put any of these chemicals on my TVs. I have heard horror stories about how they have ruined televisions and frankly, I have invested too much money in my televisions to even risk ruining them with some harsh chemicals when just plain old water will do the trick. Hope this helps.
Posted on Jun 08, 2009
    President:
  • 949 Answers
I have never seen a mfg that recommended anything but a soft cloth and warm water on it, and below is what your manual say about cleaning. You should just use what the manual says.
Use a soft cotton cloth to gently clean the screen.
2. The screen glass is very fragile. Do not scrape it with any sharp object. Do not press or tap
the screen to avoid cracking. When the screen is seriously contaminated, use a soft cloth
moistened with diluted neutral cleaner to clean the display. Wring water out of the cloth
before cleaning to prevent water from penetrating into the housing. Wipe the display with a
dry cloth after cleaning.
Posted on Apr 14, 2009
    President:
  • 1,077 Answers
DO NOT USE GLASS CLEANER.
It is recommended to use a simple alcohol solution to clean an LCD or PLASMA screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue particles all over your screen . Try and find some microfiber cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD or PLASMA part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD or PLASMA screen. You can permanently damage an LCD or PLASMA screen by pressing on it too hard.
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth.
    Problem Solver:
  • 7 Answers
I found a very good web site for protron Television problem.
Try out now . . .
http://www.ProtronTelevisionSolution.com
for find a best solution.
Posted on Jun 26, 2009
VISIO VW32L HAS NO IMAGE ON THE SCREEN. WHAT COULD BE WRONG?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 09, 2016 | Vizio VW32L 32 in. LCD HDTV
Is there a remote code for visio VW 32L HDTV
Download the user manual to your remote from net. It will have all details including code list.
May 21, 2012 | Sony RM-Y180 Remote Control
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
No Sound on 42" Visio
The easiest thing to check for is the mute button isn't activated. IF that isn't it, you might want to go thru the on screen menus and check under the audio tab. Make sure it is selected to "on" in menu. Let me know what you fine...Good luck Sincerely HDTV GURU JAY
Mar 15, 2011 | Vizio VW42LF 42 in. LCD HDTV
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
We have a 42L G30 and it has a verticle black line right down the middle of the screen. What's happening?
mostly the vertical deflection section of your tv is faulty (vertical output IC)
Dec 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Visio 42" 1080p wont power up
Sounds like the power supply section in your tv has a bad component. Probably a bad capacitor or a surface mounted diode. One thing is for sure: something has shorted and is causing your power supply section to not fire up. Suprising to me because Visio has a good track record.
May 22, 2009 | Vizio VW42LF 42 in. LCD HDTV
How to clean the screen of our 42" Visio HDTV
Vizio TVs come with a cloth to remove dust and fingerprints. If you don't have that anymore, any lint-free cloth should do. If any smears are stubborn, dampen the cloth, then wipe clean.
Never use household cleaning solutions on your screen. Some chemicals can damage plastic.
Apr 13, 2009 | Vizio L32 32 in. LCD HDTV
Lost instruction manual
Hi - You can download the manual from the link below:
MC-924JLR
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 06, 2008 | LG Microwave Ovens
Vizio L32 32 in. LCD HDTV Logo
361 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
