Question about Toshiba Satellite M45-S265 Notebook
Toshiba m45 S265. Been having power up and down related issues. Started with it not responding properly to shutting down the laptop from the desktop. It would get to the windows shutting down screen and freeze. Powering down by holding the power button down worked fine. Then a new issue started where if you ran the laptop battery down to powering off, it would do strange things when you would try to power back up. The Toshiba flash screen would come up but only half size and offset to the left. After that it would either freeze or simply go black and then freeze. Reseating the battery doesn't help. If you keep trying to boot it will eventually boot up and function fine from then on as long as you kept the battery charged or the adapter plugged in. As long as you shut it down before the battery went dead it would boot and function ok. Accidentally ran it out of battery and now I have a new problem. You can press the power button but it doesn't do anything 8 out of 10 times. when it does turn blue and you hear the fan and HD spool up, it will power off in 3-5 seconds. I dissembled the laptop, cleaned the power switch, fan and cooling assembly, reseated and plugged all of the connections, put it all back together and it booted right up normally. Great! Started checking everything for functionality, found that the WiFi card wasn't showing up on the system. Figured that I had missed a connection or the board wasn't seated correctly. No problem...powered it down, found that the board wasn't seated correctly, fixed it,and now it will only power up for 2-3 seconds before shutting down. No difference whether the WiFi board is in or not. Not sure if this is a hardware or software problem. Looking for some help here.
Trying to reinstall windows from the hard drive on toshiba m45 s265 but it asks for admin password to enter the recovery
that is usual(admin password) do you not have it?
also a frozen computer usually means that there is an issue with the reload or restore function
methinks you would do better to load operating system from restoral disk in cd reader
Jun 15, 2012 | Toshiba Satellite M45-S265 Notebook
My toshiba m24-s265 shut off when i was trying to update the bios and now it wont power up at all.
unless your motherboard has sum type of dual bios u have more likely just bricked your motherboard and will need to replace it
Mar 11, 2010 | Toshiba Satellite M45-S265 Notebook
I have a m45-S265. i turned away from it and wheni
Um, if your computer is old or used ALOT you may need a new power sorce such as a new Battery Pack or something inside could be internally screwed up
Mar 06, 2010 | Computers & Internet
Toshiba satellite m50 power issue
pls contact to the customer centre of thoshba near you.its a problem  with th monitor...
Jul 10, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S265 PC Notebook power on button
when did this start
maybe you just need to clean around power button
built up dust and dirt can cause this to happen
Feb 14, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba satellite m45 s265
Probably a broken power jack inside the machine - really common problem on laptops. You can expect $100-$180 to fix depending on where you take it.
Get a recommendation from someone if you go to a local place - lots of shoddy shops are around,
Feb 10, 2008 | Toshiba Satellite M45-S265 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
