Question about Casio Office Equipment & Supplies
The dreaded Cassio fx 115MS S-V.P.A.M.
The Basic Algebraic Functions don't work. I tried the simple A(alpha)=(alpha)B(x2(2exponent)+C (Shift) (Solve) The B? Did not scroll down. The calculator kept giving out answers in exponents of 10. I used the calc as a subsitute for the traditional = sign. this did not change anything. Can you help?
I played with my calculator, and discovered that the "EXP" function does not play well with variables using the "CALC" function. Instead of EXP, use ' x 10 ^ C ' or whatever instead.
Posted on Aug 24, 2009
HOW TO TYPE = ON FX-82
Look at the color of the ALPHA key, and find if there is a second = of the same color as the ALPHA key. If there is one, you enter it as part of a mathematical equality by pressing [ALPHA] followed by the key with the second = sign marking. However, I do not see the purpose since the calculator does no accept algebraic expression. To enter a function for a table, you select the computational mode as TABLE and the calculator will display f(x)= .
Apr 04, 2014 | Casio Brand New-Fx-82au Plus - Scientific...
How do I calculate Present and future value with Casio fx-115ms?
The calculator does not have a TVM application, so you cannot perform these calculations.
Mar 18, 2014 | Casio FX-115MS Scientific Calculator
I want to know how to calculate derivative of functions like sinx, logcosx, e^X etc on my calculator
Here it is
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
Jun 29, 2011 | Casio FX-115ES Scientific Calculator
How do you put a casio fx-115ms into math mode?
Press SHIFT MODE 1 to put the calculator into MathIO mode.
Jun 15, 2011 | Casio FX-115MS Plus Calculator
On a casio calculator how do you assign a number to the alpha functions. This could be useful, but no one seems to know. If you can't, what can you do with these letters. Maybe solving equations, but if so...
You can store values in the memory locations A,B,C,D,X and Y. To access these variables, you must precede the key by pressing [ALPHA]. Thus to access Memory variable A press [ALPHA][(-)].
To store a number in memory A Press [SHIFT][RCL] (STO) . When you use the shifted key to store no need to press [ALPHA].
To recall the contents of memory A, just press [RCL] followed by [(-)]. No need to press [ALPHA]
Say you want to calculate 3 5 and assign value to memory A
3 5 [SHIFT][RCL] [(-)] A.
Similar sequences for B,C,D, X, and Y.
I am not sure about the Casio FX300ES but the FX-991ES does have a solver mode. On that calculator, to enter the = sign in an algebraic equation use the [ALPHA] key followed by a key on the top left of keypad ( Could be CALC).
I suggest you refer to the manual for the calculator for examples of use for the memory keys. Look in the separate Appendix too.
Oct 19, 2010 | Casio fx-300ES Calculator
How can i get the shift of sine, cosine, and tangent in my calculator?
I am not sure what you mean, because your question already shows what you have to do.
To use the functions marked on the body of the calculator you use either the SHIFT key for the ALPHA key.
If a key has next to it (on the body of the calculator) two markings, the one on the left is accessed with SHIFT, and the one on the right with ALPHA. Colors of commands on calculator body are coordinated with the colors of the Shift key and the ALPHA key.
The question I am asking is whether you know what [SHIFT][COS] means. You probably do, but just in case you do not (no reflexion on your abilities)
[SHIFT] [COS] gives access to the arc cosine function, [SHIFT][SIN] the arc sine function, and [SHIFT][TAN] the arctangent.
May 04, 2010 | Casio FX-115ES Scientific Calculator
This website keeps sending me in circles
  1. I checked your problems. There are three questions asked by you. The first one concerns how to insert the = sign to create an algebraic equation. It was answered correctly by someone.
  2. The second one also concerning the = is still awaiting a solution. But it was filed under Copiers.
  3. The third question (this very one) is no question at all since you claim the site is sending you in circles.
Here is the solution to your two questions.
To insert an equal sign in an equation on the Casio FX-115ES one uses the key combination [ALPHA][CALC] (=).
To insert other variables (A,B,C,D,X,Y) you do as follows
[ALPHA][(-)] (A).
[ALPHA][' " "] (B).
[ALPHA][hyp] (C).
[ALPHA][sin] (D).
[ALPHA][ ) ] (X).
[ALPHA][S<=>D] (Y).
The only other uses of the [ALPHA] key are
[ALPHA][Integral] (:)
[ALPHA][M+] (M) to access constant memory register
[ALPHA][x10^x] (e) to access value of the base of the natural logarithm.
Dec 28, 2009 | Casio FX-115ES Scientific Calculator
How do I insert the = sign into an equation
  1. There are three questions asked by you. The first one concerns how to insert the = sign to create an algebraic equation. It was answered correctly by someone.
[ALPHA][(-)] (A).
[ALPHA][' " "] (B).
[ALPHA][hyp] (C).
[ALPHA][sin] (D).
[ALPHA][ ) ] (X).
[ALPHA][S<=>D] (Y).
Dec 28, 2009 | Office Equipment & Supplies
440 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
