Question about Maytag MZD2752G Side by Side Refrigerator
Frame where door seals is very hot
I noticed a couple of days ago the frame is very hot - I pulled the unit out and their is very little build up on the coils. THe compressor is red hot and running no fan spinning. I am wondering if the cooling fan is bad???? Any suggestions.
  • Anonymous Aug 21, 2008
    Maytag Refirgerator-Freezer 2003 Model MSB2154GRQ
    Same problem seals and inside frame extremely hot
    We are having a Maytag appliance repair person trouble shoot tomorrow
    This is our first Maytag Refrigerator/Freezer and may be our last.
  • 291 Answers
Fan should be running when compressor and fan in refrig. is running... replace condenser fan, compressor will over heat with out fan running, and refrig. cant get rid of the heat in pulls out of freezer.
Posted on Sep 12, 2007
I have a Fisher Paykel E388 upright freezer which freezes in the bottom couple of drawers but not toward the top. The motor is running and fan spins when you open freezer but stops when door is opened. Any...
Cold air always settles on the bottom Check the door seals above the cold area . Check for broken seals ,cracked seals and seals that are not touching the frame. Place a thin piece of paper between the seal and the frame and close the door . If the paper falls or is easy to pull out that may be your problem. Test at various points around the door.
Apr 06, 2013 | Refrigerators
HAVE A ED5FHEXT REFRIGERATOR MAKES A POPPING NOISE ON BOTTOM OF DOOR EVERY TIME YOU OPEN.
there is a magnetic vinyl covered seal glued all around the door frame to seal the refridgerator from escaping cold. If this seal has come loose, it will adhear to the door frame a little after opening and then be pulled back and make a slapping sound. Check this seal to be sure it is not torn loose.
Dec 28, 2010 | Whirlpool ED5HHEXT Side by Side...
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Sub Zero Freezer (501r) has frost build up at top of door frame
  1. any luck in fixing the frost build up at the top? - having the same problem with mine. replaced the seal 6 months ago and problem has now returned.
Jan 21, 2010 | Freezers
Roper side by side refrigerator gettig very hot to
Most side by side units have a hot return gas line that is attached to the "mullion strip" to prevent sweating or moisture build up which could cause mold to build up on the door seal. The heat you feel is normal, however excessive or continuous heat is a symptom of the unit running too long.
Below is a link provided by www.repairclinic.com, which will help you understand how a refrigerator works.
Tip: Make sure door seals are sealing adequately and keep entry time to a minimum during high heat periods. Use the rule "Get in, get what you want and get out"
http://www.repairclinic.com/0088_4_3.asp
Aug 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Motor stopped running but lights & ice maker OK
this is most likely a bad condenser fan motor. pull refrig from wall remove compartment cover on rear and inspect the fan that cools the compressor. it is either jammed or seized up and needs replacing. while your at it you may want to clean the condenser coils as well they most likely have dust and lint build up on them. this motor is fairly easy to replace yourself if your mechanicaly inclined the part number should be 833697blade and can be purchased online, at a local appliance parts supply house, or thru a sears parts and servie center near you.
to keep the unit working until you get it repaired you can put a house fan blowing on the compressor area to keep it cool and this will get temps back to normal and cool down that center frame as well.
Thanks Peyton..
Feb 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Constant Failure
Problem #1 solution.  Make sure that you are using a rinse aid.  All dishwashers require a rinse aid to assist in drying the dishes.
Problem #2 and #3 suggestion.  Possible that the door is either warped or not closing properly.  Make sure that the cabinetry is not obstructing the door from closing properly.  Another possibility is if the side mounting holes are used to screw the top half of the dishwasher to the cabinetry, they may be screwed so tightly that they are pulling the frame of the dishwasher away from the door causing the steam to leak out the sides.  Recommend loosening the screws slightly to allow the dishwasher frame to return to it's normal position.  Hopefully, the frame hasn't deformed.
Problem #4 solution.  You may need to replace the sump assembly as the wash motor may have a problem pump enough pressure to wash the dishes properly. The sump assembly comes as one with the drain pump included in it.
Apr 23, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MZD2752G Side by Side Refrigerator Logo
197 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
