Question about Dell (2333R) Motherboard
Signal on screen ''life warning''
It actually is a Dell 2330dn printer, What does that mean? please ignore the product name had to pick at the bottom, thank you M
AFTER CHANGING DRUM KEEP DOOR OPEN AND HOLD THE CANCEL BUTTON FOR 5 OR 10 SEC. IT WORKED FOR ME
Posted on Apr 29, 2010
  • PASEVILLEJO Sep 26, 2011
    Thanks a lot. It worked for me too. Cheers!
  • 37 Answers
I agree... More specifically, it usually refers to the Photoconductor or Imaging Drum Life... on a 2330dn, this is 30,000 pages. This is not included with the Toner Cartridge, but the Toner Cart actually docks with the Drum unit. I've scrounged all over the web and find no instructions for actually resetting the count, but the printed instructions are in the kit. They aren't real expensive, so I'd just order one up from Dell.. I think they're about $40. Very easy to change out. If you can change the toner cart, you can change the Drum.
-Robert
Posted on Jun 26, 2009
  • 326 Answers
Probably means the cartridges are running low.
Need 2nd opinion.
Posted on Apr 13, 2009
  • none863 Sep 24, 2010
    With the front cover open, press and hold the cancel button.
    Habit-Forming:
    New Friend:
  • 9 Answers
The PC Kit is reaching full capacity. If you remove the toner cart and look at the blue image drum, you can empty the PC Kit by removing the 2 screws to either side of the drum and removing the silver bar with the pressure roller. Take care not to scratch the drum else you will get black marks on your prints. (This will get messy have latex gloves available or you'll get toner all over your hands.) Attempt this only if the prints are still clean and you need to get it up and running quickly. It takes me only 3 min to clean unit out. If you have black streaks running down any part of the page, only option is to replace the PK496 drum kit. Once the cart is either emptied or replaced you will need to reset the PC kit count otherwise the message will continue to appear regardless of the fact you replaced it with a new one. To reset the PC kit count. Turn the printer off (power switch on the back) turn the printer on and when Diagnosing show press the Check and Right arrow. Continue to hold until with reset message appears on LCD panel. At this point press the Check. Wait the unit will pause for a few seconds then press the Left arrow to exit the menu and press the Check one last time. The unit will reboot and you should be ready to go again.
Posted on May 19, 2016
What does PC life warning mean - message on Dell 2350dn?
it could be that the cartridge is nearing the end of its serviceable life, I assume PC stands for Printer Cartridge. You could try getting it serviced
Feb 12, 2015 | Dell Office Equipment & Supplies
How to reset counter of dell 2330dn?
Open door and hold down the cancel button.
Sep 06, 2012 | Dell 2330dn Laser Printer
PC Life Warning on Dell 2330dn
Open front cover of printer as if you were installing a new toner cartridge. While holding it open, press and hold down the cancel button until the display says that the PC has been reset.
Feb 08, 2011 | Dell Office Equipment & Supplies
Message on Dell 2330 printer PC Life warning
I think you probably need to run the printer on a USB hub, sounds to me like you lack the power to run so many USB devices.
Mar 11, 2010 | Dell (2333R) Motherboard
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
The pc life warning light is staying on......How do we resolve this problem?
clean out the pc completely. that includes openiong the case and removing all the dust inside it. then refresh your memory with new memory, turn it on, run defrag completly and you should gain a little more life out of it.
Sep 30, 2009 | Dell (2333R) Motherboard
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
Computers & Internet Logo
5,787 people viewed this question
Alun Cox
