Question about Miele Coffee System
Miele coffee system "Fill Watertank" issue
I have had my Miele coffee system for about 2 1/2 years and just recently after filling the water tank and putting it back in, I am still getting the message to "Fill the watertank" With jiggling around and replacing back in several times i can get it to work.
  • Anonymous Mar 30, 2014
    Just opened a brand new perfecta and in the startup process it said fill tank so i filled the reservoir on the right hand side and after putting it back it it still says to fill tank.
There is a liltle floating black thing at the back of the container, this works as a magnet switch. see if it is there or is stuck and doesnt raise with the water level.
Posted on May 05, 2009
    New Friend:
I tried everything suggested on google to fix the "Fill Watertank" issue with my 8 yr old Miele Coffee machine. In the end a service man came out - after pulling machine apart we worked out it was simply the magnetic float inside the water tank had failed. $28 for new magnet .... You can order it direct from Miele and save yourself the service fee!
Posted on Oct 21, 2016
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
Oct 05, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
My Miele 615 Coffee System continually displays "Fill Watertank" Fault when the tank is full, which prevents it from operating. Sometimes I can get it to go after going through series movements...
The water tank has a black float that runs inside a "tunel" in the watertank, and that is somehow conected to the water level sensor; if you are holding the tank and looking down into it, look at the corners to find the little tunel in which this black float runs.
In my unit, this "float" gets stuck down low sometimes (I have very hard sandy water) and I get the same problem, especially during descale. It is usually fixed by opening up the tunel (it has a small tab lid) and cleaning really well with a soft brush. hope this helps!
May 26, 2011 | Miele CVA615 Espresso Machine
My Miele CVA 2660 built in is about 3 years old, the waste water fills up the drip tray in just one day, after one coffee fill. The water from the resivour "seems " to go straight to the drip...
Hi Robin,
I had this problem a year ago. Two things to check: 1. Does the water tank go all the way down so that the small notch at the back of the tank fits into the floor of the machine? 2. Any dirt at the water tank outlet?
Besides these two issues, I would say that it is very likely that the problem is that the valve of the water tank needs to be replaced. This will especially happen if the machine has been lefter without water in the tank for some time.
Good luck.
Jan 07, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
Screen says 'Fill Watertank' when watertank is clearly full.
Sounds like the sensor that detects system water levels has failed.
If you can see it inside try cleaning it or ask Miele for some advice via their website
Apr 14, 2010 | Miele CVA615 Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
I get the message Fill Watertank on my Miele CVA 620 Built in automatic coffee maker but the water tank is full. I think there might be a problem with the float switch but am unsure how you correct it
The float switch is a proximity sensor. There's a float in the tank that triggers the notification when it leaves the proximity of the sensor, located on the right side of the tank cavity. Try cleaning everything and make sure the float is moving freely in the tank.
Nov 25, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Miele Coffee System Logo
766 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
