Question about Marantz SR-5200 Receiver
Powers off after about a second
It appears the unit shorted and smoked briefly and since then it will power up. Whatever input I choose, it will identify for about a second and then power off. Is there a fuse I can check?
  • 752 Answers
If it smoked, it's NOT a fuse!! :o The output transistors are blown and must be serviced by a shop. Expect $50-$150 for that repair.
Posted on Sep 12, 2007
I Have a Harman kardon AVR 132. But it caused a problem due to power input. When I start to turn on the power appear. But after a few seconds it will shut off. So How can I use again this unit? Please
When the out put of the amp is shorted or a out put transistor if blown then the amp will not get turned on the transformer the has soft start circuit
Sep 23, 2014 | Audio Players & Recorders
It is shorting out a fuse on a 2000 ford mustang
you have a short to ground. Be very careful not to cause a fire when you perform the smoke test. instead of putting another fuse in, install a jumper wire in place of the fuse briefly and find the smoke
Oct 30, 2011 | Cars & Trucks
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Epson R280 was plugged to 220V by mistake
you can not fix it by your self you need the power input place and if it had effect the buffer device than might it would take alot mony to get fixed...
Jun 23, 2009 | Epson Stylus Photo R300 InkJet Printer
AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Jan 29, 2009 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Monitor powers briefly then goes blank
Sounds like a Control board issue or a Power board issue... Might be blown Capacitors, in which case there is not enough power being supplied. Check to see if there are cheap parts on Ebay as replacements. If you don't want to go through the trouble sell the LCD itself for $150-250.
Dec 18, 2008 | Sony SDM S81 18 in. Flat Panel LCD Monitor
Sub won't stay powered up
well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
Aug 09, 2008 | JVC TH-C30 System
No Power
Good Day, PCMcGee; To start try these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Marantz SR-5200 Receiver Logo
178 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
