Question about Home
I have been unable to switch operating mode of Balboa spa controller VS500Z from 110 volts to 220. I have 220v appearing at the neutral in that has nothing connected to it. Dealer gives up. Balboa does not give out information to non techs. What to do?
  • harolds935 Apr 20, 2009
    Turns out that the VS500Z rewires a neutral wire connection to operate.
    Seemed strange that there was 220 at the neutral lug but it is not a problem0 the nietral requires a neutral connection.
    HaroldS
I had to wire mine the same - found this on their website - check the bottom left corner - you should be all set. Good luck!
http://service.balboa-instruments.com/appnotes/VS5xx_Config_Guide.pdf
Posted on Apr 19, 2009
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Mar 13, 2013 | Balboa Instruments Pool & Spa
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
What is the difference between a Balboa VS500Z and a VS501Z
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
My spa pack says i do not have proper power polarity. and my control panel does not work
Make sure that both hot legs of the 240 volts AC are correct and Neutral is correct. The ground must be connected to the ground lug on the spa.
Nov 01, 2009 | Balboa Instruments Duplex Digital Panel 2...
Home Logo
368 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
