S-seek and back light
How do I cancel s-seek on m y satelite reciever. And how do I get the back light to come back on-is there a bulb I have to replace? Or will it come on somehow.It was on it kept flashing on and off then went out. Thanks
  • 4 more comments
  • nhjacques Nov 15, 2007
    I have an Audiovox PNP3 Sirius sattelite receiver that has a back light that works only rarely. Any hints on how to fix it?
  • jchao Nov 18, 2007
    Mine constantly shows s seek alert. Then I lose the audio. It just started a month ago.
  • Digitos Jan 03, 2008
    Same backlight problem on my JVC KT-SR3000. Started flickering, then failed completey. No model look up or parts available on JVC's website. Looks like this is a throw-away unit.
  • Wes Meyerholtz Apr 16, 2008
    Recently my Audiovox XMCK 10A receiver's backlight started to fade and then goes completely out. After I take it out of the docking station for several minutes or leave the car off along with the receiver it will again display, sometimes for several minutes before again going out. I can't find this problem or solution in the users guide. Is there a battery or bulb you can replace?
    [email protected]
  • Wes Meyerholtz Apr 29, 2008
    I contacted Audiovox and they had me send the unit back free of shipping charges and honored my warranty plus a 30 day grace period. They seemed confident they would either fix it or replace it.
  • Anonymous Aug 30, 2008
    my reciever keeps giving my a s seek alert???????
There's a "Memo" button on your PNP. If you pressed it when it was on Sirus/Sirius then it would beep a couple times a minute most likely. Try this: Press and hold the Memo button, and it will bring up a list of songs that you stored for song seek. Then you can go through them one by one and decide if you want to delete it. Use the round knob to scroll through the list, and press the knob to select it. It will give you an option to Delete it and you can go from there.
Posted on Dec 19, 2007
    Genius:
  • 1,153 Answers
What type of receiver?
Posted on Sep 21, 2007
SOURCE:
2010 Dodge Journey interior lights turn on dim when in reverse, turn off when in drive. Passenger side back up light out but bulb is good. Plate lights go on dim after closing the hatch.
Check the ground for the backup light-I'll bet it shares a ground with the interior lights.When you put it in reverse,it is feeding 12v to one side of the bulb,and instead of going through the bulb to a ground,it is seeking a ground elsewhere(through the interior light).The lights are dim because it has created a series circuit,so the bulbs are running at a lower voltage.
Oct 02, 2013 | Dodge Journey Cars & Trucks
Headlights blink when i put my blinker on
Look for a bad ground to the headlights.The ground probably feeds all of the front lights,and when you are using the headlights,they are seeking a ground through the turn bulbs.When you apply 12v to the turn bulbs,it is reversing this affect(the turn bulbs are seeking a ground through the headlights).
Dec 30, 2012 | 1997 Toyota RAV4
Hi, I looked at the back of my girlfriend's Ford Ka stereo and found a 4-digit code written on there, which I entered 3 times. It has told me to wait and has started counting down from 30 minutes. ...
that code usually is either for the tpms reset, or a satelite transmission reciever number, it will either reset the tire pressure monitor system, or enable you to recieve satelite redio servive with a subscription. hope this helps
Sep 06, 2011 | Car Audio & Video
My projection television will stay on for awhile and then the screen goes blank and the projector turns off, my satelite, my reciever, my surround sound all stays on. I am left with a blank screen with no...
When you mentioned blank does it have light on. If not check the filter for cloggging as the heat build up on the lamp can trigger a stop. Use a good forced cooling to confirm.
If the picture is clear and there is no illumination issues the bulb must be good and the issue may be power based.
If the main power supply can be cooled off , does the fault apppear, if so check the soldering of the power supply.
unless all this is confirmed the problem of the suspected bulb can stay.
Sep 19, 2010 | Televison & Video
TomTom One has lost connection with satilet
To regain connection back to th satelite, first remove it and reinstall it back, if it does not connect still, then you have to update the tom tom reciever by connecting it to a computer, remove all the maps on it, the update it from the home website.
After updating, upload the new maps back on it, the you connect it to the car system, after doing this, then you try to use it. If it does the same, then it is due to a poor signal in the area that the gps in not connecting to the satelite.
Take care
Sep 09, 2010 | Tomtom ONE GPS Receiver
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
CABLE AND SATRELLITE TOGETHER
hook up the cable box to component # 1 or hdmi 1 and the satelite reciever to component # 2. i'm not sure if this model has 2 hdmi inputs,but you can also hook the satelite reciever to hdmi 2 if it does.
Jan 18, 2009 | Samsung HL-S6187W 61 in. HDTV
Satelite reciever
I assume Dream Satellite was charging you for the use of the receiver. At any rate you will need a valid SMART card that is activated by Dream. I assume that you did not cancel your subscription also. If this happened only after the new receiver was installed you could have a bad receiver but more than likely the SMART card is the issue. Contact Dream and see if they can send you an updated one.
Sep 04, 2008 | Televison & Video
Unable to pick up satelites
hi
problem with my garmin 76csx .. the reciever shut down.. cause by pushing power and other botton while search my navigator find..
no help from my service guys i bought it from they suggest i send it in for service..
solution went to upgrade webpage.. and downloaded a software for the chipset..
system came back on line looking for satellites..
yahoo.....
Jul 04, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Picture problems
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
Oct 01, 2007 | Panasonic SC-HT40 System
269 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
