Question about Gateway Computers & Internet
Gateway lap top is not getting any power, the power light is off any solutions?
    Problem Solver:
1. First of all, go to http://is.gd/scG3/gateway/support and enter your serial number to make sure you still have warranty (just in case you need to order parts or send in your lappy) 2. You can open a chat window with gateway to describe to them your issue 3. Possibly order a new part, or fix the solution via gateway support.
ps. My suggestion is either a bad power cable, or bad battery. They will probably send you a new one of either for free if you still have time left on your warranty. Otherwise you'll have to pay, but it'll fix the issue. If you have any further questions, reply to turner.micah@gmail.com.
Posted on Apr 13, 2009
  • Gateway Master
  • 5,660 Answers
Suggest you take out the AC adapter (Charger), and remove the battery. Wait one minute, Replace the battery, plug the AC adapter back in. (AC adapter to surge protector, 'Natch)
See if it will turn on. Hold the Power On button down, until it does.
Should it not turn on, I suggest you have a problem with the DC Power Jack. This is the round opening in the laptop, where the AC adapter goes.
These little jack's undergo a lot of stress. The body of the jack, is just a tiny bit larger than the hole itself. The body is made of plastic. Let me show you an average example of a DC Power Jack,
http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1476209
That jack is about a fingernail width in length, 3/4th's of a fingernail in height, and half a fingernail wide. (I'm holding one in my hand now. I repair laptops)
The round hole has a metal sleeve, (Or a piece of flat metal at the end of the hole) The metal sleeve is the Negative connection.
There is a thick metal pin in the center. This pin is the Positive connection. Your laptop uses DC electricity.
(Your AC adapter converts AC electricity into DC electricity. A flashlight battery is an example of stored DC electricity. Laptop batteries are stored DC electricity)
Sometimes when an AC adapter is plugged in, the plug is bumped.
Sometimes this 'bump' can break the DC Power Jack. Break the middle pin loose, or the outer metal shell.
Also, if you look at the photo, you will see flat metal 'pins' sticking up. In relation to how this jack sits on the motherboard, it is upside down in the photo.
The 'pins' go down through the motherboard, and are soldered on the backside.
Sometimes the solder joints for these 'pins' can be broken. You either get an intermittent contact, or no contact at all.
Sometimes this isn't the case. Just due to normal plugging and unplugging of the AC adapter, can cause an issue.
This due to a bad design of the laptop motherboard.
The following is a crude illustration of that bad design.
Think of the laptop motherboard as being a 1 foot square. (It isn't)
Now along one edge, attach a 2 inch square. (It's actually all one piece though)
Now place the DC Power Jack on this 'Peninsula'.
The 'Peninsula' becomes cracked, right where it meets the main body of the motherboard. There are traces, (Think very flat thin copper wires), that become stretched and break.
This laptop motherboard design flaw is kept quiet. Laptop manufacturers have to replace the entire motherboard, when the laptop is under warranty, and has this issue. Also, replacing the motherboard just buys the laptop owner some time. The motherboard will break in this area again.
Could be all wrong about this. 'Google' your laptop name and model number and add -> Motherboard Issues <-, or add ->
DC Power Jack problems.
4 Suggested Answers
jassji
  • 104 Answers
SOURCE: dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Posted on Jul 16, 2009
  • 788 Answers
SOURCE: My gateway M-6309 laptop will not start.There is
Try removing the power, the battery, the Hard drive and memory.
Press and hold the power button for 30 seconds.
Re-install all that you removed.
Do not install the battery unit you have tried to fireup the unit.
If the unit comes up or if you see activity lights, you may have a shorted battery.
Make sure that you have no external devices hocked up to the unit.
Hope this works for you
Posted on Sep 22, 2009
  • 177 Answers
SOURCE: no power to my gateway m-6750 lap top. Have been
First use the following steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
If everything remain same, check the charger with a multimeter and match the voltage output with its specs.
If the charger is good, then there can be some problem with the DC jack (where you connect the charger).
Thanks
Posted on Feb 25, 2010
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
Hi my gateway just lost the light on the
Turn it off. Wait 1 hr. Restart. It could be that the video card is overheated.
Mar 23, 2010 | Gateway MT3422 RTL Notebook
When powered on, the power button lights up; so
try using a can of air, or air compressor to blow the dust out of the bottom of the lap top, try restarting it and see if it powers up, fan only comes on right away if there is a big dust build up, this should fix it
Mar 13, 2010 | Gateway M305CRV Notebook
No power to my gateway m-6750 lap top. Have been
Thanks
Feb 25, 2010 | Gateway M-6750 Notebook
Replacement video card gateway mx 3210 notebook
Unfortunately you have a lap top and the Video card is built into the motherboard. You have two choices. 1. Send the unit to Gateway and have the motherboard replaced, expensive and time consuming. 2, Replace the laptop with a new one, expensive but most likely a better solution.
Oct 15, 2009 | Gateway MX3210 Notebook
My Gateway shuts off, I don't think it has to do with the power
You are infected with a virus or something. Try re-installing the OS and see if this eliminates the problem. If it doesn't help then you have something physically defective.
Sep 20, 2009 | Acer Ferrari 3200 Notebook
Gatweway lap top button light up, but wont turn on
I'm afraid this sounds suspiciously like a motherboard problem. It would help to know what model etc, as some Gateway & EMachine model laptops have had extended warranties due to motherboard issues, or just go to Gateway.com and research it yourself.
Jul 20, 2009 | Computers & Internet
Lap top shuts off if I move the lap top-power still on but it shuts off when moved
Two most common causes: loose connector or a damaged wire running from your power adapter to the laptop.
Jul 10, 2009 | Gateway Computers & Internet
When powering on my lap top, (model mx3215) power light flickers for 10 seconds then goes out. Is the problem with the a/c adapter? I tried another adapter, same problem.
this could be 2 things, its either boot sector problem on the hdd, or its a faulty powerjack, and the pc is shutting off to protect its self
Nov 24, 2008 | Gateway Computers & Internet
Dip switch positions for cmos reset please forgot my power-on password. can you help me with this to reset please.
Open the lap top you will find clock looking batery remove batery for 15-20 minutes then put her back close the lap top ant that is it..
May 25, 2008 | Gateway 400SD4 Notebook
Computers & Internet Logo
434 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
