How to remove the play, rew-ff levers and pause button to take off the front plate of a akai gx 4000 d reel to reel recorder?
    President:
  • 1,489 Answers
Have you checked to see if there is a set screw in the handle which tightens onto the shaft? That's how most are secured. Look for a hole in the handle -- there should be a slotted screw which can be loosened with a very small scresdriver.
Posted on Apr 22, 2009
I have Akai gx 230. Its doinf Rew and FF but Play not working, though engages. Tape does not move. Can it be tape threading problem?
Could be either. If you can do some testing, check for power to the capstan motor in play configuration. If there is power at the motor terminals, the motor itself may have failed.
Aug 20, 2016 | Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
I have an olympus ds 4000 and the folders are locked. How do I unlock the folders and what causes this problem? thanks, Sherise
Hello 1 Press the Menu button the menu appears 2 Press FF or Rew button until "lock"in sub menu flases on the Display. 3 Press Menu button the file locking set up process begins. 4 Press the FF or REW button to chose between "ON" and "OFF" ON: Locks the file and prevents from being edit or erased. OFF: unlocks the file and alows to be edit or erase 5 press the Menu button to select the option. Press and hold the MENU button for 1 second or longer to close the Menu.
Nov 24, 2010 | Olympus DS-4000 Digital Voice Recorder
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Aug 01, 2008 | Olympus VN-3100PC Digital Voice Recorder
AKAI GX-747 does not play or ff or rew. Capstan runs. Stuck in standby forward mode.
My name is Ed, I have the Akai GX-747 Reel to Reel, my problem is when press the play button it engages but the capstan does not spin up to the pinch roller. The reels do not turn.
My e-mail - edward_anderson@comcast.net
Jul 01, 2008 | Audio Players & Recorders
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
125 people viewed this question
 Grubhead
Grubhead
