Question about ASUS P5GC-MX/1333 Motherboard
My lan is not working - ASUS P5GC-MX/1333 Motherboard
  • buffalonyman
    buffalonyman May 11, 2010
    Need more info....Did it ever work? Is it enabled in Bios?
  • 82 Answers
Hi... have some idea on it... did you check the proper color coding of your rj45? if the color codes are correct then the problem is in your built in lan.. try to use an external LAN card... then try it back.. thank you...
Posted on Aug 22, 2009
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
Lan card
Works exaclty like a LAN card but it uses the USB for transfering data.Look at the converters manual for more.
Feb 02, 2012 | Computers & Internet
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
INTEL ATOM D945GCLF ( LAN not working)
when you give power to computer press F2 or F1 or "del" key then enter in bios .
Then go to advanced configuration then check your lan port is disable? if it then enable it.
then check.
If it is in warrenty then take it to service shop they repalced it if it has hardware lan chip has issue.
Aug 07, 2009 | Intel Motherboard
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Jun 24, 2009 | HP Pavilion dv6000z Notebook
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Lan Problem
Goto control panel and work your way through the network Set-up Wizard.
If this is not a separte Icon in control panel then look under "network Connection" Icon.
Feb 26, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
ASUS P5GC-MX/1333 Motherboard Logo
671 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
