Question about Microsoft Windows 98 Second Edition for PC
Not possibility to print (Dos program)
I have one computer for dos program
windos 98 se (dos ver 4.10.2222)
i search file PRINTER.EXE is not in original installation
  • ilanmagyar Apr 14, 2009
    system version Windows 98 SE Hebrew enable
    file print.exe no in package of original installation.
    file print exe from dos 6.2 and operating wjth this file reponds invalid version dos
    i want a file print.exe for dos version 4.10.2222 Dos Version of Windows 98 SE
    Thank's
    this address is not opening !!!!!!!!!!!!!!!!!!!!!!!!!
    Brigadier General:
  • 5,158 Answers
  • Microsoft Master
  • 13,433 Answers
Can you tell me more about the error message you receive? PRINTER.EXE is reported as harmfull software and is not made by Microsoft nor supplied with windows 98 as it is rogue harmfull software.
Are you using windows 98 or are you using windows 98 start up diskette - dos and you want to print from the Dos`?
Posted on Apr 13, 2009
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
What is best website to show me dos programming examples.. want to creat an exe file to pick up text files from a directory and send them to a printer whenever a new file appears .(without pc...
you mean a .bat file that can be run when a new file is added. let me see if i can find a good site for you.
http://www.chebucto.ns.ca/~ak621/DOS/BatBasic.html
My advice is get a good book! One that stands out in my mind is "The Waite Group's MS-DOS Bible" (1991?) This will take you through using the command shell and batch files through how the DOS filesystem is structured, memory managment under DOS, an explaination of how the OS loads a program up to wrting little progams of you own using machine language and debug.
Another great book is Dan Gookin's "Advanced MS-DOS Batch File Programming" that will also teach you something about operating systems in general in a nice, unformal tone.
DOS also comes with a BASIC interpreter called QBASIC, that can teach you the funamentals of programming while augmenting your shell scripts and doing things that plain batch files just can't do.
www.animatedsoftware.com/faqs/learndos.htm
Aug 03, 2010 | Microsoft Windows XP Professional
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
My printer is keeps printing a deleted file!
try to delete the printer from printer & faxes.......
then reinstall both of the printer, make sure the port is right
May 18, 2009 | Nikon COOLPRINT Thermal Printer
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Microsoft Windows 98 Second Edition for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
