Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Leveling Kitchenaid Side-by-Side Refrigerator
I've lost my manual and don't know how to level the refrigerator.
Refrig. not cooling, thinking we had a power surge and now the freezer is not freezing and the refrig. side is not cooling. It makes a sound like it may try to engage, but to no avail.
Posted on Apr 20, 2009
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Leveling
Remove the kixck plate at the bottom and you can adjust the front legs by turning the feet, and the rear ones by the bolt in the same area
May 08, 2012 | KitchenAid Superba Architect KSCS25INSS...
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigoator door does not vacuum seal tight like it used to when new. Door barely stays closed on gasket.
What I hears sounds as if the refrigerator needs re-leveling. Here are some basic things to do as in this video. Every refrigerator is not always the same but the idea is to cause the doors to shut inward if you should be standing in the front and let both doors loose from your hands the doors should shut inward and firmly if not over adjusted in the final steps. Your model is a nice large model! Here is what one user manual mentioned below.
NOTE: Custom or full-overlay door panels must be installed
before leveling.
1. Open the door and place the level on top of the refrigerator
frame as shown. Check to see whether the refrigerator is level
from left to right.
2. Use the leveling bolts to adjust the leveling legs until the
refrigerator is level from left to right.
3. Place the level(s) on shelf or shelves. Check to see whether
the refrigerator is level from front to back.
4. Use the leveling bolts to adjust the leveling legs until the
5. Be sure that all four leveling legs contact the floor and
support the full weight of the refrigerator.
6. Make final check to ensure the refrigerator is level.
Adjust Door Swing
1. Check that the refrigerator door can open freely. If the door
opens too wide or you are installing full-overlay custom
panels using a Trimless Trim Kit, you should adjust the door
swing.
2. Remove the door stop screw from the bottom hinge.
3. Hold the door open to a position that is less than 90°.
4. Replace the door stop screw in the bottom hinge and tighten.
NOTE: If you are using full-overlay custom panels with the
Trimless Trim Kit, the door stop should be replaced in either
the 90° or 110° position. See "Handle and Door Clearances
for Custom Panel Series."
Install Side Panel
If the built-in area depth is 25" (63.5 cm) or more, the side panels
can be installed inside the side trim or attached to the outside of
the side trim.
IMPORTANT: Thermador is not responsible for the removal or
addition of molding or decorative panels that would not allow
access to the refrigerator for service.
1. For the inside side trim piece, slide the front edge of the
routed side panel into the trim piece.
2. Nail the rear edge of the panel to the support board.
A. Level to check left to right leveling
B. Level to check front to back leveling
A. Rear leveling bolt
B. Front leveling bolt
A. Door Stop in 130° position
B. 110° position
C. 90° position
AB
AB
Thanks, Sea Breeze
How To Level Refrigerator Doors
Apr 21, 2011 | Thermador KBUIT4870A
The refigerator is a little wobbly
Hi Wayne,
I believe I can describe the procedure.
1. Remove the front lower grille.
2. Look on the left and right front lower part behind that grille and you will see one of two things. Leveling legs or you will see bolt heads right over a wheel. These bolt heads are adjusting bolts. I ll go over the bolts because legs are fairly easy.
3. Choose the wheel in the front that is going to support your unit the best and turn the bolt just above it. It will be okay you can turn it with no problems you will see the wheel go up and down. Thats it.
4. I have posted a tip just below for you to read about leveling and doors. If you follow that you will be fine no laying the refrigerator down.
And please if you need further help all you have to do is ask.
A tip about doors.
May 29, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Door is not automatically closing. ti gets within a few inches of where it needs to be.Then it just stays open. How do I adjust level?
Some units are self leveling,by pushing the frig back (tilting it back)if this is not the case you adjust the front legs down manualy buy lifting the front up.
Jan 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
When I move the refrigerator is scratches my floor
All refrigerators have wheels, including yours.
There are also two "leveling" screws with rubber pads next to the front rollers.
Turn them clockwise (normal screw) to raise the pads so that the refrigerator is free top move around. The levelers are probably not required, so raise them up high.
I suppose that 99% of all refrigerators have the levelers raised....
Sep 28, 2009 | KitchenAid KFCS22EVMS Stainless Steel ...
I'm not sure of model. I want to level it. It's
Remove the front kick plate and you should see a 3/8 bolt head on each side . These are you leveling bolts for the front rollers . You will have to decide which one to turn ( trial and error )
Aug 30, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Leveling new Kitchenaid Fridge
Hi, Remove the front kick plate and locate the adjustment screws in front corners. Usually 3/8" or 5/16" head bolts.
Realize, there is only so much adjustment. You might have to level the back side with thin boards or shims.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | KitchenAid KSRV22FV Side by Side...
How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Jenn-Air JCD2295HES Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
363 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
