Question about Daewoo DTQ-20U9SC TV
Video The channels keep changing randomley,unless you hit the menu key. the whole thing starts right after my kid played with the buttons.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
While operating remote control any button is permanentlly pressed due to kid's playing.nothing is serious.please check it. regards
Posted on Sep 12, 2007
I have a APEX television. My kids were playing with the remote, now i have a blue screen with a red key sign on it, i can't do nothing with the television now. what do i do?
Hello
Your Apex TV ahs been locked. It can be unlocked by the folloing method.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Jul 06, 2011 | Televison & Video
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Channels keep chaning
just ensure someone isn;t playing tricks on you here. had a case recently where a neighjbors kid programmed a remote and kept changing channels while he wqs outside window.
Also check your own remote has not got a faulty or sticky button.
Sometimes a computer close by can do this or even an A/C switching in and out. Turn some other things off to eliminate this posssibilty and prepare a gallows for the kid next door if you see him in the street with a remote
Aug 14, 2009 | Televison & Video
My menu keeps popping up, and won't turn off. Even hitting the menu button on the tv won't turn it off. Soon after the menu pops up the sounds turns all the way down. The remote is not working for it...
One of two things. Most likely one of the buttons on the Tv is bad causing eratic functions. Igf so you might be able to disconnect the whole button-board. Could be the maion board in which case it's time to shop for a new TV.
May 13, 2009 | Televison & Video
RCA 52 is los the configuration after a blackout.
One or more of the buttons on the front of the set is bad. Best thing is to take the front panel off. About eight TORX T-20 screws from the back to get the speaker grille and panel off, then three more on the front and the whole panel with the button assembly will come off. Simplest fix is to just pull the plug off and disconnect the button assembly. the remote will still work.
Apr 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Box super starview
has any one got any information for putting codes in starview 3 super
thanks 817440.
Nov 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Daewoo DTQ-20U9SC TV Logo
73 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
