Question about Dryers
Dryer not working
I have a ge prodigy gas dryer that all of a sudden it will not start. I get no responce at all, not a sound, as if it has no power. I checked the outlet and it is good.
How to open a hotpoint dryer
Posted on Dec 31, 2007
  • 625 Answers
There are some switches that have to be closed before the hit start WILL FUNCTION. Most obvious is the door switch. a thermal overload in the motor circuit may have opened preventing power getting to the motor. check the overload in the blower housing. just jump it out with a piece of wire [temporarily] if it starts, replace the overload.
Posted on Sep 12, 2007
SOURCE:
Where is the igniter located on a ge profile dryer
You need to take the front off the dryer and it will be alongside the gas tube going inside the combustion chamber. The igniter is one of those curly wand types and has a quick disconnect connector on it and is secured with a couple of screws.
Here are some diagrams that might help you:
GE Gas Dryer Parts Model DPSR513GA
Good luck.
Oct 17, 2014 | GE Profile Prodigy DPSR513GA Dryer
[email protected]
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 05, 2008 | Whirlpool LER5636P Electric Dryer
Dryer does not shut off
timer motor sounds like, here is how to test:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 11, 2010 | GE Profile Prodigy DPSR513GA Dryer
Why is my dryer not produceingheat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE Prodigy dryer makes an electrical buzzing sound when I try to turn it on and it won't turn on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
How do you take the front panel off of a GE Profile Prodigy Dryer DPSR483 GAWW? There is a squeeking noise inside.
Best off to call a reliable service company such as Sears. You have to remove the top and take 2 screws off that hold the front panel on but this is a gas appliance which requires a gas technician to legally work on it.
Feb 01, 2010 | GE Profile Prodigy DPSR513GA Dryer
Gas dryer makes loud noise when first started. noise level goes down after running several minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fghgs
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
Dryers Logo
193 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
