Question about Microsoft Computers & Internet
Can't boot without entering setup
My student can't boot the system if he doesn't enter BIOS Setup. It is enough only to enter it and exit without changes, but if he doesn't enter, system is not going to boot. Operating system is Windows XP, and the configuration is with ASUS motherboard.
    Problem Solver:
  • 6 Answers
One possible cause is that the battery of the motherboard might need to be changed,
Posted on Apr 15, 2009
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
How should the BIOS be set up?
This is the recommended way to do it.Turn on your computer and press F2 to enter the system setup. If you have problems with the Bios you have to get a Bios upgrade by getting software from dell then you can do the following.Reset the boot sequence to boot first from the floppy drive or the CD drive (depending on whether your flash BIOS update is supplied on floppy disk or CD).Insert the flash BIOS update floppy disk or CD, and reboot the computer. The computer updates the BIOS and then automatically reboots. mmediately press F2 to enter the system setup program, and reset the boot sequence to the normal setting. Then exit the system setup program.
Jan 09, 2012 | Dell Latitude C640 Notebook
Toshiba portege r600 wont boot
Your BIOS settings may be wrong, or there may be a problem with the motherboard of the system.
I would check the BIOS settings on the laptop first.
When you first turn on the laptop - you might see something that says something like "Press F2 to enter Setup" or "Press Del to enter Bios" or "Press F1 to enter Setup" - or something along those lines. You will want to hit whichever key it is specifying and try to get into the BIOS/Setup.
Once you are in the BIOS, look for an option to restore defaults or reset factory settings. Do that and then save the changes and restart the computer.
If resetting the BIOS doesn't help, make sure that when you turn the computer on you are not plugged into a network cable at all.
If the system still gives the PXE error - then it is likely that something has gone wrong with your laptop motherboard. Unfortunately to get that fixed - you'll need to take it to a computer repair shop.
I hope that you can get the BIOS reset and it works for you though!
Nov 16, 2011 | Toshiba Computers & Internet
How to save exit in bios for toshiba portege 1601...because i want to install new windows so i enter bios and chage the boot order...so i want to exit save setup.
Hit escape. It will ask you if you want to save and quit.
It may also tell you an F key (such as F10) to save and quit.
It may also have the save and quit option on the last menu (furthest to the right).
Mar 08, 2011 | Computers & Internet
I have a gateway 500xl that the previous owner reformatted the harddrive wiping the xp operating system. I've upgraded the ram but without an op system I cannot turn the machine on. I need to install...
Hi there.
For this process you will need:
1) The hard drive you want the operating system on.
2) The operating system disk (Windows, Linux, etc, depending on your os choice)
3) A CD/DVD drive.
Firstly you will need to enter the BIOS on startup by pressing the Delete key repeatedly as your system starts up. In the BIOS you need to locate the boot disk priority section. You need to set priority 1 to your CD/DVD drive and priority 2 to the hard drive you wish to install the operating system to. Once this is done save changes to the BIOS and exit. Your system should now restart and on boot-up it should display a message "Insert bootable disk" or something like that. This is where you put in the operating systems install disk into your CD/DVD drive. Once it is in restart your system. Now your PC should boot up and ask you to press "Enter" to boot form the CD/DVD. Press enter to proceed. The setup should now begin, just follow the steps given by the setup wizard. Once the setup is finished and your PC reboots and on startup you get the same message about pressing "Enter" to begin setup just do nothing. Your PC should then switch automatically to your newly installed operating system and boot into it. Once your PC is fully booted into your operating system of choice remove the setup disk.
Slasher_X
Nov 13, 2010 | Gateway 500XL PC Desktop
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
I con not setup win xp on the hard without floppy disk
Start your computer. Enter BIOS SETUP. Select "Boot Order". Configure to make the CD/DVD the *FIRST* boot-device. Put the Windows CD/DVD into the drive. Save/Exit from BIOS SETUP. Your computer will restart, and will "boot" from the Windows disk in CD/DVD drive.
Jun 08, 2009 | ASUS P4S800D-X Motherboard
Problems with system booting
Try resetting the BIOS back to factory defaults
Apr 13, 2009 | Microsoft Computers & Internet
Boot failure at USBd checkpoint
There are 2 steps you can do to fix the problem
1. Change the USB Emulation Setting in the BIOS
NOTE: It is recommended to disconnect any USB devices before performing the following steps.
Restart the system.
Wait until the Dell Logo appears.
At the Dell Logo screen, press F2 right away to enter the System Setup.
The System Setup screen will appear.
Press the down arrow key to highlight Integrated Devices (LegacySelect Options).
Press Enter.
A small box with a list of devices appears in the middle of the screen.
Press the down arrow key to highlight USB Emulation.
The default setting is On.
Press the Space Bar on your keyboard to change the setting to No Boot.
Press the Esc key.
The small box disappears.
Press the Esc key again.
A small box with list of options appears in the middle of the screen.
Make sure that Save Changes and Exit is highlighted in blue.
Press Enter.
The system will then restart.
The recommended changes have now been made to the BIOS.
2. Reset the Dell Dimension desktop System Setup (BIOS) to factory defaults.
Restart the system.
The Dell logo screen appears.
Press F2 to enter the System Setup (BIOS).
The System Setup screen appears.
Press the ALT + F key combination.
Press the Esc key to Save and Exit.
Press Enter to Save changes and exit now.
The BIOS is now set to the default settings.
Apr 02, 2009 | Dell Dimension 3000® Pentium® 4...
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Computers & Internet Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
