I have a HP Pavillon 17 inch Laptop. It is two years old and recently when I power up the laptop I see a flickering on the screen ( the flickering is like the image is breaking up and parts are "mis-alligned" and the color is off a bit ( white images are now off-white ). The color issue will come and go but the flickering only happens when it is turned on and then stops.
  • 315 Answers
Try to connect your Laptop with an external Monitor... if the external monitor also flickers then its an Software problem, please try the following:
  • If your screen refresh rate is too low, you will see flicker. Right click an empty area on your desktop and click properties. Click the Settings Tab (top row of tabs) on the Display Properties window and then click Advanced, click Monitor and make sure your refresh rate is set to 60.
  • If that doesnt help you need to uninstall and reinstall the Grafics driver.
Posted on Apr 13, 2009
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Hp 2509m screen flicker
Hi Kevin,
My daughter has the same problem with her laptop, do you find that when you move the screen slowly back and forth it either stops or gets worse ?
You will need to take your laptop in to an HP dealer and let them have a look at it.
Regards :)
Feb 06, 2012 | Computers & Internet
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
HP HDX 16 laptop
check in the bios
if it flickers on the bios then needs to send the laptop in for a repair....
if it does not flicker in the bios then needs to
1> update the display driver
2> perform a recovery
regards
DJ
Mar 16, 2010 | HP Pavilion zd8000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
My hp pavilion dv9000 17 power on but see black screen
If your 9000 is under two years old, you should contact HP customer care and have unit serviced under warranty.
HP has had allot of problems with the 6000 and 9000 units and in response has offered an additional year from date of purchase.
Its worth a shut. Doesn't cost a dime.
Hope this information has helped you.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
I have a HP Pavillon DV 2000 (DV2315 NR) since
Bueno, amigo, al parecer la laptop está fuera de garantía, a menos que hayas obtenido garantía extendida. Las reparaciones de laptop son más costosas que las de las desktop, aún así te recomiendo que la lleves a un centro de servicio en tu país. Verifica primero que los técnicos posean experiencia en laptops.
Apr 15, 2009 | HP Pavilion dv6000z Notebook
My laptop screen is flickering
You most likely have a defective inverter that supplies high voltage to CCFL backlight. It is unlikely a faulty CCFL lamp because your laptop is approx 1yr. old.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the inverter or backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 08, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Screen Blackout
u must be having problem in output display driver,,,try replacing it
Oct 31, 2007 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
David Payne
David Payne
