Question about Rosewill R900J 19" Flat Panel LCD Monitor
Dell monitor Can you help me figure out how to pop the top on a dell E731FP monitor?
  • 752 Answers
If there are no visible screws, look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these either, it is probably a tension fit case and will be a challenge to open without breaking it. Youll need to find the seem and wedge something into it like a prybar (not too far or you may stab something important inside). Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Now, with that said... There's a small chance that it is Ultra-sonically sealed. This means it is basically welded shut (yes, you can weld plastic together) and is not EVER going to open without breaking. So, use your judgement to determine which is the case for this unit.
Posted on Sep 13, 2007
SOURCE:
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
This is a Dell 1703FPt monitor. Initial Dell
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd.: http://www.lcdrepair.us/1703fpt-1901fp-inverter-power.html
May 17, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
Monitor control panel keeps popping up on screen
hi..if you soldering iron or do you have a electronic technician you need help him.the defective parts need to replace is Tack switch inside the CRT/Monitor..Thanks and Good Luck...^_^
May 10, 2009 | Dell E551 15" CRT Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Task bar on bottom of screen and ribbon on top of screen disappear -- can no longer access them
why is it that it is not made clear that you have to pay to get assistance till you've taken all the time to access the site, figure out how to post, then actually post.  then here comes the money police.
I google quick, free dell monitor assistance or support and you're what I got.  I beleived you were free.
Unfortunate.
Jul 09, 2008 | Dell E773C 17" CRT Monitor
Problem with Dell E152FP Monitor
If you open the monitor up, on the inverter board is a 1000uF 16v capacitor that goes bad. If you replace that it should fix the problem. Look at the top of all the capacitors and you should see one that's popped up on the top, that would be the bad one. Some soldering is required. Make sure you put the negative white stripe on the white side of the silk screen on the board! Its a simple fix just sounds difficult.
Dec 10, 2007 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 17' Flat screen
I used to fix a 19 inches LCD flat screen from Dell. There are 4 screws at the back of rear panel and no screw at the front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Sep 12, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
Open Questions:
See all Rosewill R900J 19" Flat Panel LCD Monitor Questions
Rosewill R900J 19" Flat Panel LCD Monitor Logo
29 people viewed this question
Top Rosewill Computers & Internet Experts
Alun Cox
 Mike M
Mike M
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
