Question about Rosewill R900J 19" Flat Panel LCD Monitor
Dell 17' Flat screen
I have lost the picture on the Dell model E731FP monitor and have ordered a logivc board hoping that will solve the problem. Now my problem is ... how to pop the top on the monitor to replace the board. Can you help?? B
    Novelist:
  • 138 Answers
I used to fix a 19 inches LCD flat screen from Dell. There are 4 screws at the back of rear panel and no screw at the front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 07, 2008
SOURCE:
I have an LCD monitor, model 1703FPt. the power led on the lower panel of the monitor turns on BUT the screen remains Black Blank. nothing comes on the screen. need help.
Check the data connector on the Monitor. Not the power cable but the other one. Try changing that and see if it solves the problem.
I hope you have the correct drivers installed for your monitor based on the OS of your computer.
Jul 28, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
When i turn on the monitor, no picture--just blinking lights
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Lcd is not showing the display
As it been showing the display before?
If it has, it means the picture board of your lcd monitor as started malfunctioning or faulty.
All you need to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Dell E171FPb 17" Flat Panel LCD Monitor
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Pc and monitor turn on, monitor goes off after few seconds
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Sep 24, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell Flat Screen goes from good to bad
Check that the connection from monitor to computer are tight. Maybe disconnect and then reconnect tightly. The most likely problem if the connection if good is your graphics card. Most of the time these are embedded on your motherboard meaning the entire board would need replacing, some graphic cards are external cards that are easier to troubleshoot and replace. Try the connections and let me know. Is the computer older than the monitor, or were they purchased together? What is the warranty status?
Mar 26, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
No picture
Try to reverse the cable....use the end connected to the computer at the monitor and the monitor end to the computer. If tapping the monitor doesn't do anything and tapping the cable at the computer does the same faults then I would have it checked or just replace that cable.. Good luck.
Dec 02, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
Top Rosewill Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
