Question about Brother IntelliFax-2820 Laser Fax
Copier will not warm up. Turned off and restarted the fax but still won't print. I don't know what I pushed but is say sleep on the screen. We can not find the manuel.
  • Anonymous Apr 21, 2009
    fuser error on display.then wait ten mins.fails to warm up. heater lamp is blown.looking for replacement lamp.hard to source
  • 215 Answers
On the bro 2820 you can disable the sleep mode by entering "menu/set", "1", "6", "2" then pressing "start" and "options" simultaneously. next, press "stop/exit" key once or twice to back out of the menu mode. you'll have to turn off machine, then back on for settings to take affect.
hth,
razors
Posted on Apr 13, 2009
My Sharp copier AR 5316 does not work with Vista business service pack-1. It does not work when print option given for current page and printer sleeps and does not take the printing order. One has to...
have you installed the PROPER Vista driver? Or just used the install disk that may have come with your machine years ago, and may not be designed for "Vista". Go to sharp and download the proper driver, or at least see if it is supported.
Feb 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
Dec 03, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Printer locked up, now won't print on network
It is possible that everyone else on the network has left their previous documents sitting in the print queue. Ask all your users to double-click the little printer icon in the bottom right-hand corner of the desktop screen to see if they have print jobs queued. If so, ask them to cancel the print jobs. I hope that sorts it.
May 07, 2009 | Sharp MX-2300N Color Copier
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
Sleep Mode showing on the screen
SLEEP MODE MEANS NOTHING UNLESS YOUR USING IT WITH A PRINTER IT IS SAYING SLEEP BECUSE IT IS WAITING FOR A PRINT JOB IF YIOU ARE NOT REC. CHECK THE MODE KEY AND AMKE SURE IT IS SET TO FAX ONLY
Oct 11, 2007 | Brother IntelliFAX 4100 Laser Fax
Copier is showing warming up but will not start
the fuser unit has ceased to heat...it has a bad heater. the fuser is a hollow metal roller that usually has a powerful light inside to heat the metal. a continuity test can detect
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
remove the paper drawer and check at the back of the mc where the cassette was for paper
Sleep mode
Press Menu/Set, 1, 6, 2 (2. Sleep Time should be displayed) Simultaneously press Start and Options at the same time Press Menu/Set Press Stop Exit This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Sep 13, 2006 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
309 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
