Question about Refrigerators
How do you calibrate the room temperature display on the LG LFX25950 refrigerator? It is off my nearly 10 degrees.
bobotfel
  • 236 Answers
SOURCE: brand new refrigerator...freezer works great, fridge does not
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
sample of air vent location :
Posted on Apr 07, 2008
  • 24 Answers
SOURCE: samsung fridge freezer model number
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Posted on Oct 26, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
  • 363 Answers
SOURCE: LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: GE ARCTICA Refrigerator, M/N PSS26PSTA - poor cooling
possibly low on gas
Posted on Sep 13, 2009
The temperature displayed on the front of our fridge is incorrect, How do I fix this?
possible that the rear of the fridge needs space for the condenser to get air to cool
Oct 24, 2015 | Refrigerators
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Why is there such a big temperature gap between on-off. room temperature is either hot or cold. thermostat tried in different rooms and varying temperature settings
Normally all thermostat calibrated at the end or beginning of -2 or +2 degree difference.
I fyou set 24 degree for cool, it will cut off at the end of 22 and cut in at the beginning of 26degree
Jan 04, 2011 | Heating & Cooling
New ge fridge temp on door does not agree with three different temp gauges i have placed in the fridge. 5 to 10 degree difference?
That will happen easily if the temperature probe/thermistor is covered or located behind something stored near it. The door reading also could be out of calibration. If you have an ice maker the ice maker will not want to work very well above 5 degrees. If you run into major problems or this just started happening and you notice changes in the fresh food compartment goes above 38 degrees then that could be the beginning of a defrost problem. If you should need help let me know, Thanks, Sea Breeze
Nov 22, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Kenmore 52282 / 52284 Side by Side...
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Thermometer not reading correctly
I would guess the outside thermometer has lost its calibration.
Does it seem consistently 5, 10 or 20 degrees off all the time?
Let me know.
Regards,
Apr 25, 2009 | 1991 Buick Park Avenue
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
