Question about Sony KP-51HW40 51" Rear Projection Television
Great Sound...no picture
*The set "blinks" 9 times when turned on initially, then when I shut the TV down, and turn it back on...it blinks 4 times. Still no picture. *The "self diagnosis screen display" has the following errors... 4:v stop 1 5:AKB 1 8:HV 1 All other catagories register "0". *There is a "blue" line across the bottom portion of the blank screen. *There is a "black" bar at the bottom of the screen as well. *When the lights are out, and the TV is on, you can see faint images on the screen, but not definitive enough to make out what the images are. That's about it...if any one has any ideas, I would appreciate your help.
    Sergeant:
    Champion:
  • 375 Answers
V1 is your verticl scan has stoped for a reason,akb 1 is the feed back from the crt to the video ic, hv 1 is high voltage stop the set ,clear the error codes and start again record them and conpare the results for the true fault.
Posted on Oct 24, 2007
SOURCE:
Sony kdl52xbr9 it comes on i can see picture and sound for a couple of seconds, then it shuts off and blinks 6 times
Hi! and Welcome to Fixya!
Blinking red lights on the tv are error codes that explains hardware issues on the tv.
However, if after turning ON the tv and you will see the Sony logo on the screen before the picture goes off and then flashes red lights for a number of times, this could mean that tv can still be recovered. Try the option below to isolate possible issue with settings that cause your tv to shut off. Disconnect first all external devices from the tv
1. Turn ON tv first and wait until it flashes the red lights > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button when tv turns on
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
If that solution did not resolve the issue then a service may be recquired.
Let me know if this helps!
Oct 27, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
I have a Sony Bravia LCD TV Model: #KDL-46W5100 SN:8020524. When I turn on the TV all it has a great picture & sound. After apx. one minute it will lose the sound and then it will turn itself off. Then...
G'day Lee, sounds like you may have a 'dry joint' meaning the solder has come adrift, to open the back up will need special tools to fix it. Hope you can get it fixed. Cheers Greg.
Mar 04, 2015 | Sony BRAVIA KDL-46W5100 46" 1080p LCD TV -...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
Picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
Jun 16, 2009 | Samsung HL-R4667W Rear Projection...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony tv blinks 30+ times or once, no picture/no sound, then shuts off
sounds like a problem in the stand by power supply as the Set is not blinking any code indicating its in protective shut down. I would assume its one of the low voltage regulators that has shorted. You would need a service manual to actually troubleshoot the start up and stanby voltages. Let me know if you would like a link where to purchase the manual. I will post a link that provide free tech assistance to help diagnose and repair your set when you get a manual.
Mar 27, 2008 | Televison & Video
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Sony KP-51HW40 51" Rear Projection Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
