Question about Brother MFC 9180 All-In-One Laser Printer
Bold black lines across the paper when printing,scan or copy not on faxing
I have inherited a Brother MFC-9180 when you scan, print, or copy it leaves bold lines across the paper usually three lines on every A4 paper using the fax machine it does not do this and i wondered if you could tell me why it does this and is there anything i can do to get rid of these lines. Thanks Janet
  • May 11, 2010
    When you say it doesn't leave lines when you fax, do you mean when it prints incoming faxes, or that there are no lines on the faxes it sends?
    Problem Solver:
  • 6 Answers
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Aug 19, 2010
Brother MFC-J825DW false paper jam error
In my case that was registration actuator leaning to the side.
I was able to find it by removing back cover, and gently moving black plastic actuator to the side (stick).
It's prety well described in Brother "SERVICE UPDATE No. F1400" that I googled.
Good luck
Feb 22, 2013 | Brother MFC-J825DW Wireless All-in-One...
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
Dec 08, 2008 | Brother MFC-210 All-In-1 Print/...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 9180 All-In-One Laser Printer Logo
913 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
