Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81 57in. Rear Projection Please help us get started
We just inherited this TV. No remote, no user's manual. We do not have cable box, just hook directly to TV. We have a horrible picture no matter what we hook up VCR, DVD, we do not get any TV pictures unless we do a PIP view and then we lose audio. The picture is jumpy, wavy, lines, you name it, it has it. I just need to know if we are hooking everything up right b4 we come to the conclusion that there is something wrong with it. We were told that nothing was wrong with it except the green bar and that only affected the color.
    Champion:
  • 317 Answers
This set has a scan converter board that causes this prob. it can be replaced or rebuilt. rebuilt is the best option. by tv tech..john
Posted on Sep 12, 2007
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
How to i change the picture from antenna to cable?
TV/CABLE function
1 Press MENU, then press S or T until the SET UP menu appears.
2 Press up/down arrow button on remote until "TV/CABLE" is highlighted.
3 Press to highlight either "TV" or "CABLE", whichever you use.
Hope these info will help you.
Let me know if you need user manual free copy of Toshiba 50H72 tv.
Thanks.
Jan 05, 2011 | Toshiba 50H72 50" Rear Projection...
I'v have a toshiba 57h81 and I'm unable to get the tv and cable remote to work
first try replacing the batteries in the remote, second make sure that the remote is adjusted to "tv" using the input button. The "cable/tv " selects the input being either ant or cable. google for owner's manual for more infromation..
Jan 03, 2010 | Toshiba 57HX81 57" Rear Projection...
Toshiba 51H84 Television Questions
I'll try to respond to the questions in order;
1) This unit requires a converter. It only has an NTSC tuner not ATSC.
2) The remote will not control the converter as the coverter is too new.
Your best bet for having a songle control for all devices is to purchase a universal remote that will control the converter. I am not aware of one, but must admit that I have not really looked much. To control the number of devices you would like, the control will likely cost in the $10-$15 range.
Keep us posted,
Dan
Dec 22, 2009 | Toshiba 51H84 51" Rear Projection...
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
NEED HELP LOCATING INSTRUCTION MANUAL FOR T.V.
ct841 is the model of the remote. The model of the TV will most likely be on the back. Once you have the TV model, -->click here<--, this is the site to download the info you seek.
please take the time to give this solution a fix ya rating.
clarkco
Apr 11, 2009 | Toshiba 42H81 42" Rear Projection...
Screen went blank sound ok
Do yo have the remote? Do you have the manual? Manuals are usually available online.
If you are feeding the Toshiba with cable wiring then the problem is with the Toshiba. Maybe something as simple as the wrong input is selected on the remote control. If you are feeding the Toshiba with audio and video cables then the input to the Toshiba would be suspect. Either cabling (the inputs and outputs are plugged in wrong. If you changed anything I would retrace your steps.
Let me know by clicking on 'ask me' and if solved please do the rating. Thanks.
Jul 08, 2008 | Toshiba 65H80 65" Rear Projection...
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
