Question about Bushnell 675x5 EQ Reflector Telescope
Focusing the Barlow lens
I have a 3x barlow lens that I can't see anything out off. This telescope was given to me. The 22x lens works fine. There is a tube that goes with the barlow lens, not sure what this is. Thanks for any help.
  • Lee Sturgess
    Lee Sturgess May 11, 2010
    Hello first things 1st your barlow lens should be about 2 - 4 inches in length it consists of an eye piece screwed on to a tube,this barlow goes in the 1.25 inch hole (visual back) then your 22mm eye piece fits into the barlow,One thing will stop this from working is if your telescope is exceding its maximum useable magnification. In other words trying to magnify the image too much. You can calculate this by dividing the focal length of your telescope by the eyepiece, In this case 22mm. For example 900mm focal length divide 22mm eyepiece = 40x Magnifcation then include 3x barlow = 120x mag which should be fine with your telescope.Try screwing the tube onto the barlow then inserting the eyepeice into the barlow. Hope that helps Good Luck
SOURCE:
  • 36 Answers
SOURCE: i dont know how to use my barlow lens
I use a barlow lens quite a bit with my telescope. It is usually inserted before the diagonal if you use one or before the eyepiece if you don't. The barlow lens for your telescope will double the power of the eyepiece used.
However, despite what the manufacturer claims for your telescope things will look quite poorly if you try to view at 180 power. Generally you'll get the best images by using 50x for each inch of your objective lens. For example, your telescope has a 50mm lens. That's roughly 2 inches. 2 inches times 50x gives you a maximum useful power of 100x. Depending on the viewing conditions you may be able to exceed this or not even reach it. Things will look blurry and dim when you try to use too much power.
Your power or magnification is calculated by dividing your telescope focal length which is 360 mm by the eyepiece focal length. You have two eyepieces with focal lengths of 4mm and 20mm. If we divide 360mm by 20mm we get 18 power. If you add a barlow to that you get 36 power. Dividing 360mm by 4mm (no barlow) we get 90 power. That would be your maximum useful power.
Therefore, you should be able to used the 20mm eyepiece with or without the barlow but the 4mm should only be used without the barlow.
I hope all of the math wasn't confusing.
-jodair
Posted on Mar 25, 2009
SOURCE: Bushnell Deep Space Series 525x 78-9500
The erecting prism can be used for both terrestrial and star gazing-- put it innto the scope first.
The 3x barlow probably will NOT be very useful... it triples the power of any eyepiece. Your small scope cannot go much over 100 power-- before the image degrades.
Put the eyepiece with the BIGGEST number written on it into the erecting prism which you previously stuck into the scope... now go outside during the daytime and practice focusing on a distant object.
The bigger the number on the eyepiece the LOWER the magnification.
Posted on May 16, 2009
SOURCE: Set up a Jason 307 Explorer Telescope?
Jason and Bushnell are the same company. Here is a list of the manuals. Find your telescope-
http://www.opticsplanet.net/bushnell-warranty.html
Look down the web page.
Posted on Aug 30, 2009
SOURCE: I don't know how to work my telescope I don't
It multiplies the normal magnification of each eyepiece THREE times! In your small telescope you will probably never be able to use it. Magnification is the least important quality of a telescope.
Use the eyepiece with the largest number written on it, which is your LOWEST magnification. Practice focusing on a distant object during the day time. At night the moon should be your first target.
Posted on Nov 12, 2009
SOURCE: I have a 3x Barlow telescope that is completely
There is no such thing as a 3x barlow telescope. A barlow is a small accessory that multiplies the magnification of any eyepiece.
This is a barlow-
http://www.agenaastro.com/GSO-1-25-2x-Barlow-Lens-p/obar-gs-gs2bl.htm
Posted on Jun 01, 2010
Just bought a starnavigator 114. Purchased a Barlow lens to use with my 26mm lens, but with the barlow I can't see anything. Do I need to make changes in the lens config. in the Autostar?
The barlow may be too much magnification for that aperture telescope. The higher the magnification the SMALLER the sweet spot is in focus.
Turn the knob slower and also practice focusing during the day time on a distant object.
Mar 30, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Vivitar 76mm reflector teles.76700 barlow lens 3x eyepiece is to small for it.is there a reducer for the barlow ?kit came with two 3x barlow.same size
No the barlow increases the magnification by 3 TIMES for any eyepiece --
this will be too much for that small 76mm telescope.
Magnification is the least important quality of a telescope. Aperture and quality ioptics are much more important. I usually never use a barlow -- just the straight eyepieces in various mm sizes.
Read my tips on my profile page.
Feb 03, 2011 | Vivitar (1607225) Telescope
We have a refractor AZ2 holder (the only name we have.) No manual, several lenes, but how to put them together??? The lenses are SR4mm, H12.5mm, 1.5X erecting eyepiece & 3X Barlow Lens. Hope you can...
The 3 x barlow will be useless for this small telescope.
Put the 1.5 x erecting PRISM into the telescope and then put the eyepiece with the largest number written on it into the erecting prism. This is your lowest magnification.
Take the scope outside during the daytime and practice focusing on a distant object. Turn the focuser knobs slowly until the object comes into sharp focus.
Aug 07, 2010 | Optics
What is the barlow lens for and how do i use it
It multiplies the normal magnification of the eyepiece. They come in 2x, 3x, 4x, and 5x powers.
Normally in a very small telescope like your scope, they are completely useless! They generate too much magnification for that small aperture.
You would normally put the barlow into the telescope, and then put the eyepiece into the barlow lens.
Jun 15, 2010 | Edu-Science (10166) Telescope
I have a 3x Barlow telescope that is completely disassembled and I need instructions on how to reassemble thee entire telescope.
This is a barlow-
May 19, 2010 | Optics
Can't see anything through the lens on a Galeleo D76
I believe this is a refractor style telescope. Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x or 3x barlow if you have one.
Practice focusing on a distant object during the day time. The moon should be your first target at night.
Read the web site listed below and my TIPS on my profile page.
http://www.texasastro.org/telescope.php
May 09, 2010 | Galileo Refractor Telescope
How do i connect the barlow lens to my f70076
The barlow is inserted into the diagonal and then the eyepiece is inserted into the barlow.
Try this during the day and practice focusing oin a distant object. I think you will discover that using the barlow gives to much magnification, and makes focusing very difficult.
Put the eyepiece with the largest number written on it into the diagonal WITHOUT using the barlow and note how much easier it is to focus.
The maximum magnification for any telescope is 50 times aperture. So a 4 inch scope is 200 power. Usually you will never be able to get 50 times but only 30-40 times due to turbulence in the atmosphere.
Nov 30, 2009 | Optics
I don't know how to work my telescope I don't understand what the 3x barlow goes and what it is for I cant' see anything I tried to set up the crosshairs with the lens but can't figure it out and I have no...
Nov 11, 2009 | Meade NG-70 (140 x 70mm) Telescope
When i bought my tasco 46-114500 i did not receive my 250x lens can you help me dennis at 419-349-1983
You mean your 2x or 3x barlow. These can be purchased from many on-line retailers:
Here are two:
http://www.telescope.com/control/category/~category_id=barlows
http://www.agenaastro.com/Barlow-Lens-1-25-inch-s/66.htm
Nov 07, 2009 | Tasco Galaxsee 46114500 (500 x 114mm)...
Cant see anything out of it
These are known as toy telescopes. Put the eyepiece with the largest number written on it into the telescope. DO NOT USE the 2x or 3x barlow.
Go outside in the day time and practice focusing on a distant object.
Aug 10, 2009 | Edu-Science Optics
Bushnell 675x5 EQ Reflector Telescope Logo
287 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Ekse
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
