CPU Fan Doesn't Spin
Does the CPU fan on the VGC-LS1 always spin, or does it cycle on and off as needed?
  • robk444 Apr 13, 2009
    Joe, thanks for the prompt response, and extensive solution.. Let me give you some more background.
    I got the unit from a friend for free as he said it would not power on, and he did not want to deal with it. My profession is a Network Admin, so I figured I would be able to fix the issue, and in return I was getting a nice system for my time and "low" costs.
    I found out that the motherboard was bad and needed to be replaced. I found a honest, and reliable website (blueraven.com) that said they would send me a replacement mobo for $100, and I needed to send mine to them as a core return. This was great as a new mobo for this system is at least $800..
    So I got the replacement board, and installed it. Immediately I noticed that the CPU fan was not spinning. I tested the voltage on the board where the fan goes and it's pushing the correct voltage (5V)..
    So, I ordered a new fan... would you believe that the new fan does not work either.. I decieded to plug in the CPU fan (5V) where the case fan (12V) plugs into, and ironically, both CPU fans work, old and new.
    I am now stumped as to why neither CPU fan works where they should work, even though the board is pushing the correct voltage (5V)... This is why I thought maybe they cycle on and off as needed. I agree with you in that all CPU fans that I have come across all run constantly, however, I am stumped with this one.
  • Computers & ... Master
  • 5,660 Answers
First time that I had heard of a Sony Vaio VGC-LS1, so I had to go take a look. Pretty Cool!
I can only tell what I think from a tech standpoint of view on it's processor fan.
1.This computer is housed in a housing that incorporates the LCD screen also. It's set up just like a laptop, except the LCD screen is in the body. (Housing)
This means you not only have the heat of the processor when it's running, you also have the heat of the LCD screen.
Plus it's all packed into one tight 'box'.
Processors give off a lot of heat by themselves. If they aren't kept to a certain thermal limit, they will burn up. Literally! Like ON FIRE!
When a processor goes beyond that thermal limit, there is a built-in Fail Safe feature that turns the processor off.
In ANY computer I've seen, or worked on, the processor fan is constantly spinning. As the load for the processor increases, so does the heat given out by the processor, and the fan spins faster.
It is my contention that you have a bad processor fan. I would at least ask a tech in your area, and see if this is so.
If your computer is turning off on you while you are using it,
Posted on Apr 13, 2009
  • joecoolvette
    joecoolvette Apr 13, 2009
    Forgot to add, this is where I saw the Sony Vaio VGC-LS1,
    http://reviews.cnet.com/desktops/sony-va...
  • joecoolvette
    I have read what you stated, and am not doubting your statement for a minute, about the fan header on the mobo put's out 5 volts DC. Nor am I doubting your computer prowess.
    All I know is that the older fan's used 5 volts, and the newer fan's use 12 volts. I also believe, that with the fan plugged into the 12 volt connection straight from the power supply, that IF, it has a sensor wire, the fan RPM's will not change. Change as the processor becomes hotter or cooler. The fan will just spin at one constant rate of speed.
    Not a bad thing. Just easier on the ears if the fan spins down to a lower RPM.
Turn on cpu and it doesn't boot
open your pc panel, look for the heat-sink fan over your cpu(processor). there is a small fan over it and if it is not spinning your PC will not boot. could be a wiring issue where the wires(white/red usually) are broken or not connecting to motherboard good enough. check those but be careful no to break wires or connections. you may need to replace the heat sink module. if any capacitors on motherboard are swollen(little cylinder looking objects with + mark on top) will indicate overheating and motherboard may have failed. if fans spin on heatsink, then pc boot file may be damaged where then a shop will cost to fix it. fans will be the cheap fix else$$$
May 18, 2012 | Dell Inspiron 537 ST PC Desktop
What's your problem?tower fan is always running off and on
Your computer's Processor/CPU fan is set to run faster when it is hot and slower when it is cool. That is why it get's quiet and loud. A clean may reduce the noise, by removing the dust from the computer system the fans will be able to operate more efficiently and effectively meaning that they won't have to spin as fast.
Install fans in your chassis to provide your computer system with freash air, an exhaust fan is also an idea to push warm air out of the system. Generally the larger the fan the quieter it will be, as a large fan can spin at a slower rate to provide the same airflow of a smaller unit.
Remember that it is that fan over the CPU heatsink that is keeping your computer alive. Overtime they can wear, replacing the fan is an option.
Take care!
damnor01
Oct 06, 2011 | Dell Inspiron 531s Desktop Computer
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
The fan of the Presario CQ50 is too noisy. Any suggestions?
1.replace fan.
2..clean fan [you will have to dismantle laptop or take to shop].
If you clean your fans your self ,always hold fan bladesand dont let them spin as they can back feed and damage your cpu or graphic card. DT.
Oct 29, 2010 | HP Compaq Presario CQ60-249US Notebook
Sony vaio vgc-rc320p cpu fan is bad, do I need a 4 pin fan or will a 3 pin fan do?
You will need a new fan with a connector having the same number of pins which you have at present.
May 29, 2010 | Sony VAIO® VGC-RC202 PC Desktop
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Sep 16, 2009 | Sony VAIO VGC-RB40 PC Desktop
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Computers & Internet Logo
381 people viewed this question
David Payne
David Payne
