Question about Vintage Jukebox External Speakers Shelf System
Record won't return to it's location after playing.it just keeps turning and won't eject the record.the eject button on back of the machine won't eject record either it used to buzz when pushed now it doesn't.when i turned on the jukebox it kep't scanning back and forth about 4 times before it found the record.
  • Alan Hood May 11, 2010
    What make of jukebox do you have?
    With you saying it scans backwords and forwards it must be a Seeburg or a NSM jukebox. Can you confirm the maker and model.
    Regards
    Alan Hood
    ami-man
    UK
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Wurlitzer lyric wont play after selection
my lyric selects the record and plays but wont reste at the end the needle just stays there and it keeps spinning??
thanks craig
Apr 16, 2012 | Audio Players & Recorders
Cd stuck in 2004 VW Beetle
Soo easy just keep playing with it keep pressing the button the same thing happend with my mom and i got it out the way i told you.,DO IT WHEN YOU CAN!! :)
Nov 30, 2011 | 2006 Volkswagen New Beetle
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Jan 10, 2009 | Panasonic KX-TG2740 Cordless Phone
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
Had the same problem. Found an answer digging around and it worked: Press the STOP button and the OPEN button at the same time. Hold for about 10 seconds and it UNLOCKS.
I even went back to Bestbuy and they had no clue. But it worked!
Good luck.
Nov 07, 2007 | Computers & Internet
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
171 people viewed this question
Top Vintage Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Gilbert Ruiz
Are you a Vintage Audio Player and Recorder Expert? Answer questions, earn points and help others
