Washer does not always enter a high speed spin
Frigidaire Front Load Washer Model GLTF2940FS1 does not always enter a high speed spin. Unit was replaced once for this same problem and replacement unit has occasional occurrence of same problem. Tech has "thrown" various parts at it but nothing has worked. They finally told me it was the way we use it, that if you select "Press Saver" it will not enter a high speed spin. I guess this makes sense but still the clothes should not be sopping wet. Also the problem still occurs even in cycles that do not have the press saver option, such as the "Heavy" setting. Also, "Rinse and Spin" does not always extract the water. The clothes just tumble back and forth for 10-12 minutes then machine shuts off.
    Problem Solver:
  • 14 Answers
Look for blockage at inlet of water drain pump i found a sock in that area and it fixed my problem same problem you have
Posted on Feb 15, 2011
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do I fix E56 high motor current error on Frigidaire GLTF2940FS1
  1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free?
    No. Replace the motor.
Yes. Go to step (3)
2. Spin the tub pulley. Does the tub spin free?
No. Check the tub bearings.
Yes. Go to step (3)
3. Disconnect the plug from the motor and measure the resistance of the windings (pin1 to pin 2, pin 1 to pin 3, pin 2 to pin 3). All readings should be between 4 and 6 Ohms.
If the readings are correct, replace the speed control
board.
If the readings are incorrect, replace the motor.
Apr 30, 2014 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer model 41744052400 will not enter into high speed spin at end of cycle. I can run the test for the different cycles and can get the high speed spin, but only in the test mode. ...
Try to get the repair manual for your machine, it's worth the cost. Meanwhile, with the power unplugged, undo any wire connectors that just plug in and check for corrosion. Check the capacitor, a dent will ruin it.
Nov 26, 2013 | Hotpoint WMA64 Front Load Washer
Frigidaire Frontload Washing machine Model GLTF2940FS1 will not spin out the water all the way and the clothes remain soaked with water. The drum does a few rotations in both directions but then shuts off...
Good Morning Lydia,
Based on what you have described and since you have already replaced the pump and checked for any possible kinks, at this time I would recommend reaching out to a professional to proceed further. The washer may possibly be experiencing an issue with the door lock assembly, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, a diagnoses is highly recommended.
Thank you for allowing me to assist you in some small way!
Sep 08, 2013 | Frigidaire ATF6000ES Front Load Washer
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
Nov 08, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Won't go into high speed spin at end of cycle.Spins slowly and reverses direction instead of high speed spin to remove water from clothes
Hi.This is a common problem for this model.You have a bad speed control board.The board is mounted on the rear lh base of unit .Replacement is easy, part costly.Two screws hold the board to the base and there are 2-3 quick disconnect plugs.You'll need model number to get correct one.Hope this helps .Please rate my response :)
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer will not spin
Two possible reasons the lid switch may be defective, or the spin bearing may be worn.
Aug 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
