Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Trying to install Roady 2
I have changed cars and trying to install my Roady 2 in my new car (don't have  instructions)
My new car does not have a cassette player (only a CD player) and my Roady 2 has the cassette  connector...Will it work in my new car?  If so, what to do?
  • Delphi Expert
  • 509 Answers
The Roady2 and most of the SkyFi2 units were the LAST units to have the super-powerful (FCC said it was too strong) FM modulator built into the radio. IF you don't plug anything into the audio jack, the FM modulator will be active: go into the MENU and set the FM Frequency and match your car radio and you'll be all set. Good luck and let us know how it worked out for you.
Posted on Feb 27, 2013
  • 60 Answers
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Posted on Jun 06, 2009
My Roady XT turns itself off after 2 hours. Why does this happen?
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Mar 27, 2010 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT. Changes channels by itself. Can I fix that?
Try a new wall plug/adapter. You need the 5V adapter from Belkin. Worked like a charm for me--after suffering with this problem for a week....only cost $10.
Jan 08, 2010 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi roady home kit won't change channels
Solved my own problem! Press the Preset/Direct button located just above the 5and 6 on the bottom of the receiver. You should now have" Direct" displayed in the top left corner of the display.You are now good to go.
Oct 26, 2008 | Delphi Roady Xt Home Kit Sa1017611p1
'Antenna' message on Roady
Hi there check the back of the docking staion. The connection is LOOSE or try to make sure that you have not keep it in the sun for to long just let it cool down
Rate FixYa Expert Kindofcheap
Aug 30, 2008 | Delphi Roady SA10035 XM Radio Receiver
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
225 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
