Question about Konica Minolta PagePro 1350W Laser Printer
Have replaced drum and toner and printer still will not work
Printer stopped working and it was assumed that the drum needed replacing however after replacing drum it still doesn.,t work
  • 3 Answers
If you refilled the drum, you will need to replace the chip in the drum
Posted on Apr 15, 2009
Magenta toner does not print, printer says its full. Worked just fine until I opened the drum unit to clean drum with q-tip (I am getting black dots all along the page). After that, the magenta stopped...
Take the toner cartridge out and try to turn the Developer roller ( the toner coated roller), if it doesn't turn you have a faulty cartridge. If the cartridge is OK, recheck the Magenta drum to see if the thin corona wire has been broken. You will need to remove the Cyan toners to get to the corona wire cover. If is damaged or broken, the whole drum will have to be replaced.
Sep 25, 2013 | Brother HL4040CN Laser Printer
I just installed a new drum and toner cartrideg last week and the error message says drum is near end. Should the toner cartride be replaced?
After replacing the drum and toner you may need to reset the drum life of the machine. This is how to reset the drum life:
Open the front cover where the drum and toner are located. Press the clear/back key. Lcd should show Replace Drum? Then press 1 for yes. Lcd should show accepted. Close the front cover the press stop/exit. Lcd now should show the date and time.
Hope this helps. Rate if it works. Thanks
May 02, 2011 | Brother MFC-8460N Laser Printer
My Brother HL2140 printer was running fine and all of a sudden the toner light is on and it stopped printing. Just yesterday when i printed out the status for the drum and toner it showed more than 80 %...
636 is a lot of pages and depends on the toner coverage you may need to replace the toner.. 80 - 75% (is that used is remaining ??) any way check your waste toner basket first (see you manual for instructions) chances are its filled and needs cleaning or replacing (see your manual for instructions) If its fine then change your toner .. If you have the demo toner (toner shipped with machine) these contain less toner than a new cartridge and will finish faster ...
Jul 26, 2010 | Brother HL 2140 Laser Printer
Do you get a new drum with a toner replacement cartidge or is it a separate thing you have to buy
Hello.
The drum and toner cartridge are separate items. Both are replaced by the user.
The toner cartridge holds toner/ink. The drum does the work. You will need to replace the drum for every 4-5 toner cartridges used.
I've seen toner cartridges for your printer at $36 vs $60 for a drum.
Hope this helps.
Jun 13, 2010 | Brother MFC-7440N Laser Printer
Drum Unit Warning will not stop after replacement
Hi there
You need to get into the menu and in there reset the toner,
All best Pineworks
May 04, 2010 | Brother MFC 420CN All-In-One InkJet...
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
Stopped printing, need drum? but no light on
Hi! sandy; Your printer not really heavey duty one, and you give them big jobs, for a sample, you give adult jobs to the baby, it not going run, so your machine need a break! nothing wrong just give them little bit rest.
May 06, 2009 | Brother HL 5250DN Laser Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
