My screen gives me a big black box. i did the reset using the replacing battery while holding clear the calculator wouldn't turn on and took out the batteries and put them back now the screen is black again
Adjust the brightness setting...
Posted on Aug 26, 2008
Had you left it in direct sunlight for a long period or perhaps in a very hot car? Sounds like the LCD is damaged.
Posted on Sep 12, 2007
Press 2nd button and down arrow, you might just need to adjust the brightness
Posted on Nov 04, 2008
SOURCE: my ti 83 plus calculator wont go on
First of all, and I mean no offense here, check that
the batteries are inserted correctly, respecting the polarity +-+-. The
flat part (bottom) of the battery is the one that sits on the
protruding helix-like electrical terminal. Inside calculator, there is
polarity diagram.
When you change batteries, the display
contrast may become too dim (too light) for the user to see anything.
In that case, it can be adjusted.
Adjusting the screen contrast. Here is how to do it.
There is a key labeled 2nd. It is blue on the TI84Plus, and yellow/orange on the TI83Plus.
The
lack of screen contrast is the most frequent cause of 'malfunction'.
Try readjusting contrast, as described above. If that does not solve
the problem, post a comment to this thread detailing what you did and
the calculator response and we will troubleshoot further.
Good luck.
Posted on Dec 11, 2009
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Posted on Sep 16, 2008
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
Posted on May 08, 2009
SOURCE: TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Posted on Sep 09, 2009
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1). Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system. Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
(Procedure 2).
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Jan 29, 2008 | Texas Instruments TI-83 Plus Calculator
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
3,093 people viewed this question
I have the same problem, insert new batteries and the screen goes black. I even had the case on it the whole time and not in direct sunlight. Does any one know of anything i can do besides buy a new one.
I had the same problem of the screen going black after replacing the batteries. Mine was never in direct sunlight, it was on a shelf in a closet. Any suggestions??
black screen
I had the same problem and was also just stored inside an office desk and am looking for a way to fix it.
I am hav ing the same problem. My screen went black after I replaced the batteries and it was kept inside of an office desk.
Wow, I have the same problem, I left it in my pencil case with the cover on, tried inserting new batteries, even the backup. Screen is still black.
same problem what can i do?
I have the same problem. Tried holding down the del button while taking out battery #1 and putting it back while holding del and on,
but doesn't work.
