Question about Lexmark C530dn Laser Printer
Lexmark C530dn 120.03 fuser error
Lexmark C530dn color laser printer, just purchased today gives a error code of 120.03 fuser error after powering on for the first time today.
    Genius:
  • 1,018 Answers
If you just purchased the printer today, place a call to Lexmark repair and ask for either a new printer or warranty repair.
Make sure you have your sales receipt ready, you will be asked for information about the transaction.
Posted on May 20, 2009
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
Corysf62
  • 188 Answers
SOURCE: low voltage power supply
What is the error message you are getting with the new fuser. Is this the same error you were getting before changing the fuser? If you changed the fuser because the old one was just at EOL ( end of life) but did not give you an error, have you tried to reinstall the old fuser.
It is possible that the new fuser was damaged in shipping, or not properly seated.
If both the new and old fuser give the same error message, then yes, I would agree that the LVPS would be the next part to replace, however, if they have different errors, then you probably have 2 bad fusers ( or one that is EOL, and one that was received damaged).
Before changing the LVPS, make sure you follow the steps below prior to the LVPS steps.
as far as where to purchase it if you do in fact need one, you can always do a google and ebay search for "Dell 5100cn LVPS".
I can provide you with replacement instructions if it comes to that.
See below for the actual troubleshooting needed for the fuser.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
  • 1684 Answers
SOURCE: The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Posted on Jun 19, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: C530dn lexmark PC Unit Life Warning
    Hi, I believe you will have to replace the PC units pretty soon, Here is an article that explains the process pretty good, plus it gives you the step by step guide on how to reset the PC units once the new ones are installed.
    http://bit.ly/b0bndZ
    Posted on Jan 28, 2010
    Lexmark printer ... X 543... has 122.05 fuser error code... can this be reset?? customer thinks power went off then back on...
    Normaly when the printer sends a PRINTER FUSER ERROR it has to be replaced, check the counter for the number of copies and verify (according to manual), also check the fuser if it's not stuck with a peace of paper or other debrie...
    Jan 04, 2011 | Lexmark X543dn Laser Color All-In-One...
    I have an error message 120.10 service fuser error, what does this mean?
    Service Fuser Error appears when the fuser does not warm to the required temperature to operate properly. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
    Oct 11, 2010 | Lexmark C530dn Laser Printer
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    Jul 05, 2010 | Lexmark C530dn Laser Printer
    Invalid engine code?
    Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
    Apr 16, 2010 | Lexmark Optra T612 Laser Printer
    120.07 Service Fuser Error
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    Jan 04, 2010 | Lexmark C530dn Laser Printer
    Nov 11, 2009 | Lexmark E250dn Laser Printer
    920 Fuser Error
    Jun 26, 2008 | Lexmark E342n Laser Printer
    Lexmark c530dn printer
    Hi there the best thing is to use an alcohol based cleaning fluid and a soft cloth.
    Spray the label with the fluid after removing all consumables of cause. then wipe the area with cloth and the label will start to break down repeat until label gone then try printing.
    If the label is stuck in the fuser section then replace fuser same if stauck on drum.
    Thanks J
    Feb 05, 2008 | Lexmark C530dn Laser Printer
    900.00 Service
    When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
    http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
    Go through the suggested steps to try to narrow the problem down.
    But if it needs a firmware update:
    http://support.lexmark.com/printerfirmware/
    Use code: Isfap129 to download the package the C530dn.
    Hope this helps!
    Nov 29, 2007 | Lexmark C530dn Laser Printer
    Lexmark C530dn Laser Printer Logo
    843 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
