Question about Ariens Garden
I have an old Ariens R M 830 and I am puting on a 12/hp electric start engine. Do you have a wireing printout . I am rewireing every thing. Thanks
2 Suggested Answers
  • 62 Answers
SOURCE: I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Posted on Sep 25, 2009
Testimonial: "This is exactly what I did and found the clutch safety switch was sticking closed.Thanks a lot for your suggestion and help."
Need wiring diagram to change from 6 volt to 12 volt. Have '48 8N tractor still on old 6 volt system need to rewire to 12 volt system
Only thing needed is to change battery , leave wires alone , unless there is a wiring problem , wiring diagrams are avalible on internet, pdf ...
Nov 19, 2017 | Garden
Blades will not engage on Ariens A22A46
Some Ariens mowers have electric clutches. You can check for it and wiring to it. Maybe a wire is disconnected, wore thru etc. It sounds like it's not engaging.
Oct 14, 2016 | Ariens Garden
Why won't my Ariens 46 in 20 hp BS eng. turn over when key is turned to start?
It could be several things. First see if the safety switches work One switch should be under the seat. The second could be a bad solenoid which will not allow the current to go through the wire. Thirdly the battery connector could have a break in it. Electrical problems can be tricky to track down.
May 18, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
Need the wire diagram to rewire my Ariens lawnmover to bypass the safety switch. It is Ariens GT-19 model # 931026 Serial # 001463. Can you help? It is an old Ariens mower but still runs good but now I...
here is owner manual:
http://apache.ariens.com/manuals/030305C.pdf
usually the switch is behind the ignition, sometimes at the N position of gearshift, just look for a switch with one wire coming in & one going out (usually the same color); disconnect the two wires & jumper them together to bypass the switch. Looks like yours has one under the seat.
Apr 25, 2017 | Sport & Outdoor - Others
My typewriter model NAKAJIMA AE-830, having problem, when i select the alphabet 'A' and the printout is 'q'.kindly advice what went wrong.tq
On the L. side of the keyboard there is a slide switch for pitch, slide it up & down a few times and leave it in 10 or 12. not in PS.
DickyO
Aug 23, 2010 | Nakajima AE-830 Typewriter
I took the wiring harness and the compents, key switch, selenoid, starter and etc from an Ariens 930e and put it on my 830 and now the mower will pull start without the key and it wont stop running when I...
Make sure the harness ground is grounded to the engine,if it is,the configuration will be different in the key switch,and you will have to use your old switch.But switching the switches can cause a melt down so be care full when plugging the other switch in,and trying it out.
Aug 22, 2010 | Garden
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
Sep 22, 2009 | Garden
New 12hp tecumseh engine won't fire
IF THE ENGINE WILL TURN OVER WITH THE KEY YOUR PROBLEM LIES WITHIN THE ENGINE ITSELF
PULL THE SPARK PLUG AND LIE IN ON A GROUNDED SURFACE WITH WIRE ATTACHED TURN ENGINE OVER AND VISUALY CHECK FOR SPARK
IF STILL NO SPARK YOU WILL NEED TO PULL FLYHEEL TO CHECK POINTS AND COIL
IF YOU NEED ASSISTANCE IN THESE PROCEDURES LET ME KNOW
Sep 19, 2009 | Garden
Garden Logo
217 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
