Question about Epson Stylus Photo R1800 InkJet Printer
Epson R1800 refuses fine art papers
I'm going nuts trying to get my Epson R1800 to accept fine art ink papers like heavy weight Hahnemuhle Photo Rag. These are supposed to be supported by Epson, right? So when I press print usually the printer fails to pick up the paper, sometimes it pulls it through rapidly without printing and about 1 try in 50 it makes an exquisite print. Is there a setting I'm missing besides "Matt Paper -Heavy Weight"? My photographer friends complain about this problem. Any ideas?
  • Anonymous Jan 02, 2008
    I have the very same problem. The 1800 won't load or print heavy weight or paper that is not exact sizes that Epson makes. It seems epson printers are set up only to work with epson media. What a drag. I would love to know if a solution exists for this problem
  • Anonymous Mar 27, 2014
    its not feedig paper but the printer responds to the print command, the problem is that its failing to pck up the paper
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
Posted on Sep 25, 2007
  • Anonymous Sep 26, 2007
    Hi Again Fruitless,
    Just a further note to the above posting. Just ignore what I said about CS3. It doesn't matter what editing program you are using as this "Thick Paper" box is in the maintenance tab of the printer dialog box. Not sure what I was thinking there. When you get to be over 60, brain farts are not uncommon! But sometimes we stumble/bumble upon some really useful things, and this was one of them. Enjoy
    New Friend:
I just found this post while searching for an answer to the same problem. I've been using my R1800 for about 3 years to print on Epson double-sided matte paper and now it suddenly won't accept it at all. The paper just passes directly through without printing and I get the "media loaded incorrectly" message. If anyone has come up with a real fix for this, pls post it. Thanks.
Posted on Jan 08, 2010
    New Friend:
With paper over 250 gsm you need to feed it in via the feeder in the back of the printer (attach paper feeder that goes in the back). Set it to Roller manual in page setup, you need to put pressure on the paper to feed it in and the printer will grab it. If you get any smearing It may be helpful to set the paper to thick in the 'extension' print settings (Mac). Its explained here files.support.epson.com/pdf/r1800_/r1800_ug.pdf
Posted on Dec 19, 2009
I have been stuggling with this tonight too, except with Epson Glossy 13x19.  I kept getting the "Media Out" error when i tried to print it using the sheet feeder.  It turns out that by puting a few blank sheets under the one I was using it lifted the paper enough so that it sensed it being there.
Hope this helps someone else!
R. Joe
Posted on Oct 18, 2007
    Problem Solver:
  • 18 Answers
Could be paper dust built up on the sensor that scans your media, (usually a blue light on HP printers). check for a visable light scanning the media as it enters the carriage area. You might try getting the media directly from Epson. http://www.epson.com/cgi-bin/Store/pamPaperFinder.jsp?BV_UseBVCookie=yes&printer=53540919
Posted on Sep 12, 2007
My answer to paper not picking up R1800
All settings for paper type and size should be set first ( I'm sure you have this done already). Make sure you have good view of paper pick up point. press the printer paper button (top right of front of printer). as the rollers start to pick up an hopefully drag the paper help feed it in from both left and right sides of the paper, once the paper has been through the rushed feed and come out the other end, hopefully it will have cleaned the rubber rollers  ( you can't see them they are inside, they help pull the print through slowly and allow the paper to be printed on). My rushed through sheet had a dirt on what would be the bottom left edge this was approx half a cm by about 1 cm. Wipe of the dirt from the paper place this back in the tray ready for printing. then continue to print.(I used the on screen printer manager that pops up saying jobs stopped resume job to restart the job). I will say that I have 10 sheets of premium photo A3 in my rack at the moment and have the last sheet turned round but actually I believe the dirty rollers to have been the problem. just and extra suggestion and totally I accept no resposibillity you could try holding on to the paper a bit and let the rollers slide over the paper in the hope of cleaning them. As paper is run through the printer small deposits of fiber must coat the rubber wheels, especially if you have been using water colour type paper. Good luck.
Posted on Jun 06, 2008
I have tried everything. The thing that is working as of this moment, and has worked for the last 10 sheets is to take a coated heavyweight sheet and leave it sitting in the back of the feed tray and place the art paper on top, hold and feed it - put pressure on end of paper with your hand. The coated sheet must lift it slightly and maybe make the surface smoother to slide on - by the way, make sure the printable side of the coated sheet is facing the back of the paper tray so that the smoother, back side is backing up your art paper. good luck!
Posted on Feb 01, 2008
The "thick paper" check box is under "extension settings" in the Photoshop print dialog on my mac.
Posted on Feb 26, 2008
SOURCE:
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
Mar 20, 2011 | Epson Stylus Photo R1800 InkJet Printer
HI I have EpsonStylus Photo R1800. I just changed an ink cartridge and now the paper and ink lights are flashing alternately...it has been working fine all day...
Try unplugging your printer at the back, where the power cord goes in. Leave it out for about 30 seconds then plug it back in and try again. Sometimes they just need to be reset, or restarted. Let me know if I can be of further help
Oct 20, 2010 | Epson Stylus Photo® R1800 InkJet Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
There are black ink smudges on the bottom corners and edges of my color prints on velvet fine art paper. How can I stop that from happening. I already cleaned the heads twice. The prints are great...
The R2400 has an option to load paper on-top (Epson calls it the Automatic Document Feeder) and at the back. Based on the printer's User Guide the Velvet Fineart Paper should be loaded at the back. (Epson called is the Manual Single Sheet Feed).
Look at the User's Guide availabe on their website.
Jan 19, 2010 | Epson Stylus Photo R1800 InkJet Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 wheel marks on print
you can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Jan 23, 2009 | Epson Stylus Photo R1800 InkJet Printer
HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
Hi
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Rollpaper feeding problem on R800 Epson
try to look at your rollers made of black rubber, if they are shining then they need cleaning, if you know how to open the unit to get to all these rollers then you might be able clean them yourself with laquer thinner and a rag, where gloves and turn the rollers into the soaked rag and keep turning tight with lots of elbow grease until all rollers lost that shine.
Jan 18, 2008 | Epson Stylus Photo R1800 InkJet Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
1,373 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
