Agitator not spinning hear sounds inside the shaft
My problem is about the agitator its not spinning i can hear only the sounds that i believed is coming inside the agitator or the shaft itself
  • 6,784 Answers
Hi, this agitator may have stripped all of the internal gears and plastic drive adapters that allow it to preform its actions during the selected cycles. The only solution here will be to replace the agitator and drive shaft as well. you can order a complete agitator kit with all the parts as well. this will fix this issue. Please rate and god bless:)
Posted on Apr 13, 2009
GE washer wvsr1060dww will spin but not agitate I can hear like a really low sound when I turn the timer
Number 310 is the agitation drive block. Inside it is a plastic spline. That spline over time will wear out and slip. The result no agitation.
The agitator snaps down onto the drive block. To remove it place a rope under the agitator and lay a board across the top of the machine. Get a large pipe or screwdriver and twist the rope around slowly till the agitator pops off. Note some models have a screw that would need to be removed under the agitator cap but yours ain't one of those I believe.
Training/Service manual
Good Luck Amigo!
Aug 11, 2012 | Washing Machines
I have a GE top loading washing machine. The agitator has stopped working and the drum no longer spins at the end of the cycle when the water drains. What can I do to fix it and get the agitator...
When the agitator on your GE washing machine does not work correctly, the most likely cause is a worn drive bell. The drive bell sits on the agitator shaft inside the agitator. The shaft and the inside of the bell lock together using splines. When the splines inside the drive bell wear out, the agitator will not rotate correctly. To repair the agitator on the GE top loading washing machine, you will need to remove the agitator and the drive bell.
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator out of the washing machine. If the agitator will not budge, rent agitator hooks to pry the agitator out. Agitator hooks are available at appliance repair stores. Set the agitator hooks under the agitator and push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft with a small flathead screwdriver. Use a socket wrench to remove the hex head bolt at the top of the drive bell. Carefully pull the drive bell up off of the agitator shaft. This may take some force depending on how stripped the inside of the drive bell has become.
4. Inspect the inside of the drive bell. There are splines inside the drive bell that line up with the splines on the shaft. Most often the splines inside the drive bell have worn, causing the shaft to spin but not the drive bell. Also inspect the notch on the outside of the drive bell and the notch inside the bottom of the agitator. If either of these are worn, replace the drive bell and the agitator.
5. Take the drive bell to an appliance repair shop to purchase a new part. If you need to replace the agitator, take the old one with you as well. Compare the new parts to the old ones, making sure they are identical.
6. Position the new drive bell over the agitator shaft, lining up the splines on the shaft with the splines on the inside of the drive bell. Set the securing bolt back into the top of the drive bell and tighten the bolt down until it pushes the drive bell down until the bell bottoms out. Push the new plug on the top of the agitator bell with the palm off your hand until the plug locks into place.
7. Place the agitator over the drive bell and slowly rotate the agitator until the notch inside the agitator lines up with the notch on the outside of the drive bell. Tap the top of the agitator down with the palm of your hand until the notch on the agitator locks down over the notch on the drive bell. The agitator will not bottom out flush with the tub.
8. Close the washer lid and plug the washer power cord back into the wall socket.
The defective agitator is the cause of the drum not spinning. So get the agitator fixed and it should solve the spinning problem.
Good luck.
Apr 22, 2011 | Washing Machines
Agitator came off the shaft.
should be able to just lift agitator off the shaft check threads on agitator and shaft
Jan 03, 2010 | Washing Machines
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
Washer won't agitate
With all other aspects working... The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline. It is still cheaper to pay the repairman and part replacement then a whole new unit, When calling a repair person tell them that your machine will spin but no aggitation, don't tell them you think... most are honest and fair, to save some if you can take the machine to the repair shop it will save you some service charges.
Feb 10, 2009 | Amana NAV3330E Top Load Washer
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
May 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
