Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Pull cord is locked: not the reload spring
Tried taking some advice; took four screws out to remove cover to see if that was the problem to allow pull cord to work. Found out it's not the prob, the actual fly wheel is jammed up that the cord pulls to start.
Where to go to now? Remove the bolt on top?? many thanks to whoever has a tip.
    Scholar:
  • 152 Answers
Often times I fear this part. But it seems there are a lot of frustrated people on here that no one is getting back to. So here goes....
If the flywheel is locked up, then the engine is locked up. Sorry.
Posted on Apr 14, 2009
The pull cord on my snowblower wont pull
First thing to find out is if the engine will turn over.. Check the oil level in your engine... if you got lots of oil...then ..pull the spark plug out of the engine...if you can turn the augers on the blower by hand then your engine is not seized... So the only thing left to check is the spring that acts as the recoil of the "pull cord". Usually there are screw holding the cord cover on. Note: You didn't mention if the cord was coiled in the machine or dangling out of the machine.... If it is dangling out..then it will be a broken recoil spring...if it is in could still be broken or perhaps just got pulled out of the locking device. Solutions: Take the cover off.(this is the part that the cord goes into)..then take the cord holding portion off the blower...it can removed once you have all the screw/bolts off. Nowd unwind the coil and make sure that the end is attached to the casing...if it isn't check the end of the spring ...it may be broken...it not broken check the casing where the spring end would be anchored/connected to allow it to coil up into. if either is broken than you have found your trouble... If you don't find anything wrong or if your not sure it is connected properly take the whole assembly to a repair shop...they will tell you if it is okay or not..and this should cost your nothing.... Good luck, I hope I was of some assistance to you.
Feb 23, 2015 | Garden
How to replace the cranking pull cord?
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
Mar 28, 2014 | Mtd 22" Yard Machine Push Mower
How to get to wiring plug
If you're talking about the cord that you pull out from the reel located at the rear of the machine, you'll have to take the top cover off first. Usually two philips head screws located under rear exhaust cover and one maybe two near the front end. Once that is removed, there will be two more philips screws, one on each side of the top rear of the machine and one on the bottom. Remove all three of them, pull about a foot of cord off of the reel and get it to catch, the using the heel of your right hand, hit the very back of the machine, (the rubber bumper part) on the top with a motion pulling toward the back. This may take a couple of tries if you're not used to removing this part, but one or two swipes should eventually loosen the rear cover. Once it is loosened you may carefully pull it out of the back end of the machine and take off the two wire connections. This will free up the cordwinder assy. so you can take it to a spot where you have some room to work. Now lay the assembly on it's back and take the four screws, one from each corner of the rear cover, out and lay them aside. Thread the cord plug through the opening and wind the free cord back onto the reel, allowing the spring to pull it slowly out of your hand and then wrap the plug end around and around the reel till the spring is unwound, then you can remove the "C" clip from the center post, sometimes hidden under a cardboard washer. With the clip removed you can gently pull the cord reel up and off the post, carefully bringing the rewind spring up and off it's post as well. If you've tested the cord and are sure that it's your problem then you can cut the remainder of the cord from the reel and throw it away. The reel is easier to deal with without the cord on it. Turn the reel over so the back cover is exposed, there should be three screws that can be removed so you can take the connections loose from the posts inside and make ready for the new cord. Once you've attached the new cord and tied your strain relief knot, like the one you removed, you're ready to wrap the cord onto the reel and just reverse the procedure. When you get ready to put the loaded reel back into the cordwinder body, just before you put the cover on, wrap the plug end around the reel three times. This loads the spring so that it will pull the cord completely back into the unit. And it doesn't hurt to drop a spot of oil onto the top of the post for the spring.
Nov 11, 2013 | Electrolux C101 Bagged Canister Vacuum
How to put new pull rope on a husqvarna 44
Remove the four screws securing the starter to the saw. take a piece of starter cord 3.5mm diameter approx 86cm tie a knot in one end, Remove the single crew securing the rope pulley and remove, feed the new cord through the hole in the pulley, re fit the pulley to the cover, make sure the spring engages into the back of the pulley, feed the cord through the hole in the cover and re fit the the starter handle, now hold the cord in the cit a way in the side of the pulley and sart to wind the spring up by rotating the pulley, allow the pulley to re wind pulling the cord in,
Apr 02, 2012 | Husqvarna 44 61 268 272k 225 Chainsaw Gas...
Replacing cord on polaris 250 ATV ??
CORD? THE ONE TO START THE ENGINE.
Park the Polaris ATV on level ground in an area with plenty of light. Allow the engine to cool if it is warm so that you don't burn yourself.Remove the four Phillips head screws from the corners of the metal cover that the cord is coming out of using the screwdriver. Pull the metal cover off the engine. Unwrap the cord from around the turn wheel completely.Spin the turn wheel using your hand until the nut securing the cord is at the top of the wheel facing you. Grab the metal stem on the cord with the pliers. Loosen and remove the nut using the box wrench. Hold the stem to keep the cord from turning as you loosen the nut.Pull the cord off the turn wheel and through the hole on the metal cover. Keep the nut just in case the new cord did not come with one. Insert the metal stem on the new cord into the hole on the metal cover. Insert the stem into the hole on the turn wheel.Tighten the nut onto the stem the opposite way than you removed it. Spin the turn wheel counterclockwise until you hear the spring lock into place. Wrap the new cord around the turn wheel. Make sure that the cord does not overlap itself. Replace the metal cover to the engine. Replace and tighten the screws to secure the cover to your Polaris's engine.
  • Dec 04, 2011 | Garden
    How to put a new pull rope on it How do I put a new pull rope on
    It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
    Aug 18, 2011 | Husqvarna Chain Saw 20" Bar
    How do I replace the pull start?
    Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
    May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
    How do i install new cord to my tap head echo model gt-22ges trimmer
    Can you verify the model number please. Models for Echo usually have 3 numbers and sometimes a letter, I do not have a gt-22ges in my data base.
    Apr 30, 2011 | Echo Garden
    The started cord will not recoil
    remove the top cover. take the three or four screws out, turn cover over, the spring has broken or slipped. if it has slipped, remove the cord by untying the knoe in the handle, pull the cord from the inside of the pulley, remove it completely, hand rewind the spring in the opposite direction that it pulls in, holding it is a trick, get someone to hold it after you rewind it, rethread the cord thru the cover hole and thru the hole in the pulley, tie a knot in the end, pull it into the pulley and slowly release the pulley, carefully. put the handle on and replace the cover on the machine.
    Sep 18, 2009 | Garden
    Cord doesn't retract, so I took it apart ...
    Pardon the long winded answer. I have had a similar same issue on this trimmer TWICE in the first 3 months. What I found on my trimmer is that there is a spring buffer/assist built into the starter assy between the rope pulley and the plastic part that engages the cogs on the motor. The plastic part that engages the motor has a hole in it to retain one end of the spring and the other end of the spring fits in a slot in the rope pulley. The plastic part with the hole appears to be poorly designed and allows the spring assist spring to fall out of the hole and jam the entire assembly preventing the rope from returning. Pulling it apart allows the recoil spring to escape from under it's cover and prevents it from engaging. Yes, removing the spring can be a little exciting -- take your time and cover the housing opening with a towel before removng the spring to keep it from flying across the room. I rewound the spring by driving a nail into my workbench and using it to retain the center hole and wound the spring until it would fit inside the metal spring cover. There's a bump in the outer winding that fits in a hole in the spring cover and then it slides over a peg in the plastic housing. The cover will retain the spring as you put it back into the housing as long as you take your time. The circled inner end of the spring should show in the center hole and it engages the other part of the recoil assembly that engages the cogs on the motor. Check to see if the assist spring is engaged on both ends before tightening the 3 retainers. All-in-all a pretty poor design that has me looking for another trimmer and this one's going in the trash.
    Aug 07, 2009 | Homelite Mighty Lite Lawn Trimmer
    Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
    137 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
