Question about Roper 24 in. RUD3000 Built-in Dishwasher
Roper dishwasher not draining
I have a roper dishwasher and I'm not sure of the model #. The problem I'm having is the water is not draining completely and water is standing inside when the cycle finishes. Is there a way to remove the drain screen in the bottom to see if it's clogged?
  • Auriu Jan 05, 2008
    I have a Roper Dishwasher also not draining. The cycle finishes and the water is standing in the bottom. I tried checking for a clog. I vacumed the water out through the drain hose but water still will not drain through here.
  • jimmy9879755 Feb 13, 2009
    My Roper model WU3000X4 does not drain
SOURCE:
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 67 Answers
SOURCE: Water in bottom
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If this helps please vote me a fix ya
Posted on Jul 14, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
  • 639 Answers
SOURCE: dishwasher will not drain. General Electric 4200 series
Dear friend,
ngfam at you service! happy to assist!
Check for debri and food at the bottom clogging the drain. Be care full of your fingers in case there is broken glass don there!
Other wise it may be a weak pump and then you better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water is holding up inside the dishwasher where the water drains
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Mar 27, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water in back of Roper dishwasher
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 19, 2010 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper dishwasher washes, seems to run normally, but leaves a couple inches of water in the bottom when done
If the drain is stoped this will happen. Is it a new instalation? If into a disposer did you knock out the plug in the disposer. Check the drain line
Oct 17, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher on no water
Is the water valve under the sink on? Any kinks in the hose? Check to see if the water valve solenoid coil is open (located under the cabinet front).
Oct 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
My roper dishwasher won't drain
Check the following to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 11, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Water in refrigerator
Defrost drain under evaporator in freezer. Inside back wall of freezer has to be removed to access drain
Oct 05, 2017 | Roper RT21AKXKQ Top Freezer Refrigerator
Water In Dishwasher Won't Drain
Dishwasher Problems - Water will not drain out
heatman101
a
Jul 13, 2008 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Roper 24 in. RUD3000 Built-in Dishwasher Logo
886 people viewed this question
Top Roper Dishwashers Experts
Mike
Kevin
Kevin
paul
paul
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
