Question about Gateway M360 Notebook
Gateway problems I have a Gateway laptop I purchased the extended warranty and cannot talk to anyone Gateway so my laptop model M360 will not power up the connection port has a very loose pin in the center is there anyway to talk to anyone at Gateway about this issue or do I have to fix it myself.
I have a gateway nv44 and it will on power on if the screen is in the right position. I have to hold down the power button and move the screen up and down until it come on. Then it works fine.
It sounds like you have worn, loose or cut wires at or near your laptops hinges. You need to contact gateway if it is under warranty or the purchase place if you have an extended warranty through them. If it's out of warranty you will have to find a technician that repairs gateway laptops or pay for gateway to fix it.
Oct 04, 2013 | Gateway NV44 fan - NV44 laptop cpu cooling...
Push power button it lights up for 3second then shuts off what is wrong with it
Could be bad ac adapter or bad motherboard. Have seen lots of cases where the ac adapter was bad and the laptop no longer starts after the battery goes dead.
Jan 10, 2013 | Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD...
I have a gateway laptop/notebook model # m360, I would like to upgrade the video card...is this possible. I have the new sims 3 game I would like to play
highly doubt it is possible due to the fact that majority of laptop Video controllers are ONBOARD and therefore cannot be removed
Jan 04, 2010 | Gateway M360SB Cel M-1.3GHz/ 256MB/ 40GB/...
Emachines monitor e15tr model 568 wont come on
Try to connect the monitor to the VGA-output port of some other desktop or notebook computer. If it does not work, then it needs repair or replacement. If the monitor still under warranty:
* standard 1-year warranty from Gateway
* extended warranty that you may have purchased from Gateway
* extended warranty that some credit-cards offer for items purchased with that card
* extended warranty that you may have purchased from the retailer
If not, it's probably cheaper to replace a 15" or 17" or 19" monitor
that it would be to try to repair it.
Nov 27, 2009 | E-Machines eMachines Monitor E15T4
Gateway Laptod Model No M360
First you will need to register at gateway, I took the serial number you provided and gateway has no record of it, once you register it, you should be able to purchase the recovery disks. I'm including the link:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=gateway&sn=0000000000 you need to register in order for this link to work, that serial number has to be in gateways system, once it is you can order recovery media. Hope this helps
Nov 18, 2009 | Microsoft Windows? Vista Home Premium...
Does the MA2 M360 motherboard has jumpers that
Most modern motherboards have no jumpers that need to be set.
Oct 06, 2009 | Gateway DA0MA2MB6D8 6000 and M360 Series...
Gatweway lap top button light up, but wont turn on
I'm afraid this sounds suspiciously like a motherboard problem. It would help to know what model etc, as some Gateway & EMachine model laptops have had extended warranties due to motherboard issues, or just go to Gateway.com and research it yourself.
Jul 20, 2009 | Computers & Internet
Lost serial # for a Gateway notebook Model MX 6425.
It may be difficult to get Gateway to honor the warranty with the sticker missing. The receipt from when you purchased the laptop may have the serial number on it. If you can find a friends battery and get the computer on for a few minutes, sometimes the serial can be found in the BIOS. Belarc Advisor also can sometimes bring up that information, but you would have to get into windows to do that. How did you find out about the extended warranty?
Jun 25, 2009 | Computers & Internet
Mortherboard,keyboard replacement on gateway m360
First I would ensure my video cable was firmly connected. Sometimes that connector does not seat all the way causing what you are seeing. That is the rectangular connector leading fro the cable on left side of the LCD to the motherboard. Normally there are several hardware components related to a white display. LCD, video cable, or motherboard all causes of white screen. Have you checked external video? What was the original issue before motherboard and keyboard replacement?
Mar 14, 2009 | Gateway M360 Notebook
Gateway M360 Notebook Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
