Question about RCA L42WD22 42 in. LCD Television
No sound or vid input
No sound comes out and none of the output are working
  • morganmil May 13, 2009
    no sound and neither vid outputs are working only hmdi
  • TONY BIGNELL May 11, 2010
    Do you have any picture or on-screen display?
    Problem Solver:
  • 5 Answers
Sounds like the famous failed fuse issue. The manufacturer installed an undersized fuse on the main board, about 2 inches from the tuner pack it has a "F" on it. This must be replaced with a larger, 750ma, 63 volt chip fuse. Unless you're adept at small soldering, get a tech to replace it and the set should be fine.
Posted on May 29, 2009
Connect a CD player to LF320EM4A
Hi, plug red and white rca connectors from cd player to audio in - rear of tv.
Feb 02, 2015 | Emerson Televison & Video
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
Aug 28, 2009 | HP Pavilion Elite M9150F Desktop PC
I can't use the vcr on my tv, only the dvd player.
Most vcr's should have an line output or coaxial output. If you hook it up to the turner on the tv, then you have to use channel 3 or 4. If you use the input go to vid 1 or vid 2 or whatever it says on the input.
Aug 10, 2009 | Memorex Televison & Video
Trying to hook up system to tv and can't get sound after doing so. what should i do?
output on tv to input on unit.. make sure the unit is in the proper mode that corresponds wher you hooked the wires into ex. aux. vid.1, vid2..
Jul 31, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No sound output
Sounds like you sorta know what your doing but the most obvious answer is the source and output (selection) dont match. Double check your mute button and all the obvious things first, make sure your connections are to Zone1 inputs as well. None of those are it? Do you get sound from the Radio? Try unhooking all inputs (video also) and hooking up just one at a time till you get it right.
Mar 18, 2008 | Audio Players & Recorders
RCA L42WD22 42 in. LCD Television Logo
462 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
