Question about Kenmore Refrigerators
How can you tell if your coolant has leaked out of your refrigerator?
My refrigerator is not cold. The repairman just left and said the coolant has leaked out of the refrigerator. Is the freon colored or clear and should I be able to see it?
  • mccorm ick06 Apr 13, 2009
    I have frost on the coils a third of the way up. I have replace the defrost heater, what next?
    Sniper:
  • 56 Answers
Freon is a clear gas while at room tempertaure.
You would not see it.
Freon leakage is normally one of the last things to go wrong with a fridge.
You may want a second opinion.
Posted on Apr 13, 2009
Fridge cold stopped working and now freezer shutting down, had for 2 years.
call a certified repairman it might just need a little coolant .if there is sulfur in the area where you live that usually gets into the solder joints and causes leaks
Jul 14, 2015 | Refrigerators
Question about Amana ABB1927DE Bottom Freezer Refrigerator. Freezer is cold, but does not freeze. Refrigerator works fine. Suggestions?
Coolant leak or gone
compressor going bad
thermostat going bad
Hard to tell without access to it.
Aug 25, 2014 | Refrigerators
FREZZER WORKS FRIDGE DOES NOT
Same thing happened with our fridge. We had a repairman out to look at it. He took the back panel off the rear of the freezer. There was a large block of ice in one corner of the freezer. Repairman said this was indicative of a Freon leak. The condensation was freezing around where the leak was which was why the block of ice was in one corner rather than all over. Repairman said he could refill the Freon but cost 200 dollars. He also said there was no real way to tell how quickly the Freon was escaping so the fix could last 2 years or 2 weeks, there was no way to tell. Repair company came highly recommended from yelp as well as Angie's List with many high marks for honesty. Repairman suggested buying a new fridge (not from them) for 300 bucks rather than a 200 dollar fix with no way to tell how long it would last.
Aug 15, 2012 | GE GSS25SGMBS Side by Side Refrigerator
My hotpoint fridge RLA34 isnt keep my food cold
you'll cooling coils may be dirty thermostat may be going bad or it might be just a setting worse case a coolant leak requireing a repairman
Jul 30, 2012 | Hotpoint Refrigerators
If the coolant from the freezer compartment leaked, will the refrigerator still work (stay cold)? I know the freezer won't work. thanks.
There is only one coolant circuit for a refrigerator. There is a fan that circulates the cold air from the freezer side and pushes it through the refrigerator side and that's how that gets cold. So if all or some of your refrigerent leaked out then the refrigerator will have to be repaired by a qualified technician if you still want to use it.
Sep 17, 2010 | Haier HNSE05SS Stainless Steel
Had a repairman fill coolant (8oz) and now the
Too much refrigerant. Let some out until the frost back starts going away. Do it slowly.
Sep 08, 2009 | Refrigerators
Repairman stated he cannot fix refrigerator coolant leak
what you want to do is replace the coolant tubes in your fridge... i would suggest calling in another repairman and see if he says the same thing please rate my solutions... please.
Jun 30, 2009 | GE GSH22JFR Side by Side Refrigerator
Sub-zero not keeping cold. It will cycle on and cool properly, then after a while the temp goes up to near 50 and it takes too long to cycle on to cool down again.
Call a subzero repairman. My subzero had a leak in the refrigerant coolant tubing. Trust me, only a trained and equipped repairman has a prayer of fixing this.
Mar 16, 2009 | Sub-Zero 650 / O Bottom Freezer...
My car heater is blowing cold air
The shut off valve on the heater core was left shut during the repair on your coolant system. the repairman forgot to re open the shut off valve . this is the problem. open the shut off valve and, the air will become hot again. as for the gauge fluctuations, the actual gauge may be malfunctioning.
Feb 24, 2009 | 1996 Toyota Corolla
My 8 ft Hussmann freezer is working, but not cold at all
Unfortunatly, your repairman is correct. The evaporator section (part that makes things cold) of this case is build into the wall and if it is leaking it is not repairable.
Dec 17, 2008 | Hussmann HUS-LBN8 Self Contained Frozen...
Refrigerators Logo
325 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
