Question about HP PSC 1410 All-In-One InkJet Printer
Cleaning the printer head?
My documents are coming out very light - even with brand new ink cartridges. Sometimes only half the line will print. I think the problem has to do with the printer head. Can this be cleaned or cheaply replaced?
    Problem Solver:
  • 18 Answers
Print heads are built into the ink cartridges on HP's. I currently have this problem with another hp model. I appears that the firmware is stuck in what is called 'econo mode' and won't come out of it. good luck. sorry not more help.
Posted on Sep 12, 2007
6ya staff
SOURCE:
Black printing very faint or not at all, cleaning print head makes little difference Brand new Cartridge
Sometimes it will print faint black even if there is a new black cartridge, because the color cartridge needs to be replaced as well.
Make sure that the cartridges are genuine Kodak cartridges, as well, for maximum performance and reliability.
Cleaning heads can use up a lot of ink, by the way.
Jan 13, 2011 | Kodak ESP 5 Printer
My 5180 will not print black. it has a new cartrigde
Your print head is separated from your cartridge. I think that your print head is clogged, and that is why you can't print even with a new cartridge. The cartridge in your case is just a tank with ink, the print head is inside the printer.
You can do a software cleaning to unclog the print head.
  1. Click "Start", then "All Programs", then click on HP and then click on "HP Solution Center"
  2. Click on "Settings"
  3. Click on "Print Settings"
  4. Click "Printer Toolbox"
On the "Device Services" tab, click Clean the Print Cartridges and then follow the onscreen instructions. There are three levels of cleaning available, depending on how long you haven't print.
When the printer is done, it should print a test page. If everything seems ok, just print. If not, you will need to repeat the procedure.
You should also know that software cleaning uses a lot of ink.
Hope that will help solve your problem!
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Good Luck :0(
Nov 12, 2009 | Epson Stylus C84 InkJet Printer
Pages are coming out completely blank...ink is fulll...i have cleaned the print head
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Oct 16, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Prints half the line
It sounds like your print head is dirty. Try cleaning the printhead in using the printers options, If that does not work replace the black printhead.
Jun 15, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer will print pictures, but won't print documents.
Sometimes this happens because the ink dries in the print head. If multiple cleaning doesn't improve it you can try cleaning the print head itself with alcohol or an electronic spay can type cleaner. This should fix the problem for you. Also resetting the cartridges in the slots sometimes improves the ink flow.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Inconsistent Print following installation of a new black ink cartridge
try head cleaning twice or thrice so as to improve the ink flow in the head. wish u success.
Jun 01, 2008 | Canon PIXMA iP1600 Printer
HP PSC 1410 All-In-One InkJet Printer Logo
461 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
