Question about Canon Pixma iP4500 InkJet Printer
Paper jambed and then I got the message error #5100.
  • 4,041 Answers
Hi You can Try 2 things.
you can only try.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 10, 2010
Error message
If looking into the paper feed there is no visible jamb, check the outside of the printer elsewhere. There is usually an access panel that comes off to manually remove any caught paper from behind where your paper loads to copy.
Sep 19, 2013 | Oki Electric Industry B431dn Printer
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
Hi there have got a cannon pixma 492 had problem really since i brought then recently cant use had for 12mths only use a few times a month paper gets jammed then error 5200 please help i dont know what to...
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Jun 09, 2011 | Canon MP490 InkJet Printer
I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
Samsung sf-5100 Fax machine - no paper
Check inside the paper tray area to see if the paper sensor flag is dislodged. Otherwise it will be a board problem. Vacuum clean out any toner spill. Try a can of compressed air to blow any paper dust from any sensor. They will be the little black U shaped devices. Make sure the flafs move freely in and out of the sensors.
Jul 24, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon Pixma iP4500 InkJet Printer Logo
150 people viewed this question
old marine
old marine
