Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door goes up but will not go down.
Hi there, we have a chamberlain power drive door opener which is ok to go up using the remote, will not go up using the switch in the garage unless you press the lock button at the same time. The light on the garage wall switch has also gone out. The up function will not work form remotes, again the only way to fix is by pressing the lock key as well as the up/down button. I will really appreciate you help with this matter.
Gloria
  • donniemorris May 17, 2009
    I have the same problem with a genie garage door opener
  • 504 Answers
UNPLUG THE UNIT AND WAIT 5 MINUTES.
THIS WILL RESET THE CONTROLS.
SEE IF THE WALL BUTTON LIGHTS UP.
IF THIS DOESN'T SOLVE IT GOTO CHAMBERLAIN.COM AND DOWNLOAD THE MANUAL (FREE PDF FILE) IT WILL TAKE YOU THROUGH A COMPLETE DIAGNOSTIC.
HOPE THIS IS HELPFUL
Posted on May 27, 2010
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi. My garage door opener is having a problem closing. It goes about 1/2 way down then reverses to the open position. Its a chamberlain 1/2 hp heavy duty. Any suggestions?
Hi swilson.... on the motor you will find adjustment screws. One to adjust the up setting and one the down. Also one for the pressure setting. Usually when the door is behaving as yours is the pressure setting needs to be tightened a bit so that it does not reverse direction with the tiniest bit of resistence. Make small adjustments so that you do not end up with a door that is a safety hazard in that it will not reverse when it hits an obstacle. Joe
Thanks for choosing Fixya!
Dec 01, 2010 | Chamberlain 12HP Power Drive Chain Drive...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
1,618 people viewed this question
Top Chamberlain Car Audio & Video Experts
Vince Heuser
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
