Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
My cd rom not reading any cds - LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
  • LG Master
  • 19,396 Answers
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Posted on Apr 21, 2009
3 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: DVD/CD-ROM Drive just stopped reading all discs
Have you tried using a good quality dvd cleaner? Alot of times a dirty laser will cause this problem. After cleaning try using a known good dvd and see if it works. If not check your device manager to see if the drive is functioning properly. If there is a yellow ! then the drive either has a corrupt driver or it has died. You can replace it fairly cheap as a dvd/cd burner can be replaced for around $45 max. Hope this helps.
Posted on Jul 11, 2009
babes_ganda0
  • 381 Answers
SOURCE: compaq presario V3500 CD rom
so it might not have read is that the broken wire Ribbon or your player may foul the lense, try to untangle and check up these possible damage inside, have a nice day
Posted on Jul 28, 2009
Cd/dvd cannot read cd content in some cds
If your laptop is still on guarantee, return it ,but if its expired ,then replace DVD ROM.I once came across this problem ,but it was on emachines D620 ,replacing DVD ROM solved the problem.
Feb 06, 2013 | HEWLETT-PACKARD HP ProBook 4520s Notebook
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
Lenovo laptop not booting from any CD, But able to read other Cds
you can check by disabling all other driver to boot except from cd rom. if it fails again then try with a new bootable cd written in low speed, if still it fails then try with a new rom
Jun 25, 2009 | IBM Computers & Internet
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Does not read cd's
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
Jan 21, 2008 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
1,122 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
