Question about Lexmark X75 All-In-One InkJet Printer
Paper jams to sides on x5470
I have a x5470 that is jamming the paper when i try to print. I could use some help on this one i think the rollers are jamming but i cant find a service manual to see the parts
  • Lexmark Expert
  • 228 Answers
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Apr 14, 2009
Testimonial: "This is a very god solution. I was at one time a Xerox technician and these steps were the ones used to fix most printers. I got so used to them being cheap and disposable that i never look at them as fixable. Hence I have had several printer that was easier to replace than to fix. I thank you for reminding me that its worh the money i spent to fix them."
Lexmark X5470 printer displays message "Clear paper jam, then press (check mark). There is no paper jam and it will not print with the message showing. I have cleaned the rollers but it didn't help.
try taking all of the paper out and then just print one sheet.
also make sure that it is new paper, lays flat and that you have fanned it prior to inserting it in the printer.
Jan 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper keeps jamming, seems to want to pull on one side only when part feeded. x5470
then check out the roller by dismantling the printer. check if the roller has jammed in one side where the paper does not get inside..
Mar 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
My lexmark is jammed
did you have any jams recently where the paper was badly damaged, and or came out in pieces? If so there may be a small amount of paper still jammed in the printer, out of sensor range. try looking deep into the bottom of the paper path and around the roller.
Feb 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly installed won't stop jamming paper
Paper Jams in the Printer ID:412
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam...and no paper is in side
make sure the machine is clean inside and you have the right paper
Jan 01, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
