Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan 5500 I am having problems with my generator after it runs for about 30 min +, it runs fine at first, then the engine rpm's fluctuate up and down then shuts off. code 36 is the trouble code. I have replaced the fuel pump, fuel filter and spark plugs. air filter is fine. i removed the carb and checked the float(appears to be fine). I have not checked the jet or cleaned it. It seems as though it is a fuel issue. Is it possible to be starved of fuel after time? Could air develop in the line? Could it be "overheating"? Would these symptoms be from valves sticking? I have not checked the power output? I am only running 1 ac and fridge when this occurs. Any suggestions of what it may be or things to check? Any advise would be appreciated. Has anyone else experienced this before? Is it a common occurrence? Please help thank you
  • 116 Answers
Well they have an expensive card in there that controls rpm and voltage to maintain 120v. there is a safety for oil temp in some of those maybe bad try bypassing it after it heats up to pin point it. maybe time to clean brushes?
Posted on Apr 17, 2009
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Oct 16, 2013 | RTO Cummins Onan HomeSite Power 5500
Oman 6.5 watt generator in 1986 winnebago does not run at normal speed
This is called hunting and it is because the load sensor is not working
Apr 15, 2013 | Watts Onan Portable Generator - 5000 ,...
When i start the onan 5500 it takes 4 or 5 times then when it does start it runs low then high rpm then low again where do i start
Adjust the carberator. You have to do this while the engine is running and it usually takes a straight slot screwdriver. You can turn a spring loaded screw to adjust fast or slow which ever is needed.
Aug 05, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,817 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
